Question about Sharp AR-5316 Advanced Digital Imager Copier
AR-5316 - H2 keeps on appearing
The digital copier keeps on blinking with letter H and number 2 alternately and all buttons are not functioning
  • amir hamza
    amir hamza Jul 19, 2013
    press # interrupt c interrupt . Display goes off press 14
  • Sharp Expert
  • 318 Answers
Press # interrupt c interrupt . Display goes off
press 14
Posted on Jul 19, 2013
  • amir hamza
    press 14
  • amir hamza
    press 14
I need operating code AR-5316
Posted on Mar 11, 2008
  • amir hamza
SOURCE:
Sharp AR-5316 ERROR I have a digital copier Sharp AR-5316. It only puls a 2 and a H
H2 : mean thermistor is defective.
to resolve this problem you have to choice if the first one didn't work go to the next one
  • do the following procedure to reset the error :-
press "R" key __ "Interrupt" key __ "C" key __ "Interrupt" key __ "14" __ " ready" key
  • If the first procedure didn't solve your problem contact your customer service center to replace fusing thermistor.
thank you for using fixya
Feb 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Pls help for sharp copier AR-5316 error code 2-H
H2 signal is thermistor open
check the harness and the connector between the thermistor and the PWB use TC 14 to clear the self diagnostic display.
Oct 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
My ar-5316e photocopier displays the number 2 followed by the letter H ... plz help
www.sharp-ro.ro/dyn_pdf/doc-AR-5316E-96.pdf
vinhco.com.vn/download/AR-5316SERVICE.pdf
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-5316
service manual and user manuals above.
Jun 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Blinking with L and 1 alternately
Hi:
L-1 is caused by the scanner lock being partially or fully engaged. The scanner lock is located under the left front corner of the machine. It should be a round plastic dial. Make sure it is in the unlocked position. If you crouch down and look under the left front corner you should see the dial.
Andrew
Mar 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
165 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
