Vertical black line what do i solder to fix it
    Scholar:
  • 135 Answers
Hi There!
Check the board on the Right where the Tuner is located. That board is normally the culprit. Also solder the surface Mount ICs but be careful when using Hot Air Soldering. Turn the Air Flow down so you don't blow the tiny components off the board. If not familiar with Hot Air refer to repair Technician. Good Luck, Jus004
Posted on Mar 11, 2008
I need to fix a large black vertical line on my Samsung 50" plasma t.v. What part do I need?
if you know how to troubleshoot your tv you can by finding defective capacitor in the vertical section of the PCB board inside, replace it with the same value. use multitester, soldering lead, iron and pump when removing the defective parts, i suspect the caused of black vertical line in your tv was a defective 30v/1600uf or up capacitor.
Dec 06, 2016 | Samsung Televison & Video
I have a LCD Panasonic Viera. There is a 2 cm long vertical black line middle of the screen. What can I do.
There are videos on YouTube on how to fix the black line problem on plasma TVs. There is specifically a nine year old boy named Nico that shows how the repair is done. It is a simple problem but time consuming because you have to take the back of the TV off and maybe two other large parts. The problem is caused by solder that separates or breaks and you just take a small tipped solder iron and reflow the solder. It might take someone that doesn't know much about TVs, a couple hours but it is fixable. There is an AV forum online that shows pictures and instructions on exactly how it done:
http://www.avforums.com/forums/plasma-tvs/462873-black-line-fault-hyundai-hpt4240-fixed.html
While the posts on this forum are old-most of the plasma TVs are basically the same as far as how to fix the problem. We're getting ready to takes ours apart because it has a black vertical line on the far left of the screen. Our problem started about a year-and-a-half ago but we've just been too busy to fix it but I'm tired of it so we'll try it.
Feb 18, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a JVC AV-32950 and have lines running across the top 3 - 4 inches of the picture. The picture also goes black on occassion and I have to hit the top of the TV to get the picture to come back. While...
It may be a dry solder point somewhere near the vertical IC. First take look at the solder points and if you found cracks pls resolder it. if the lines continous you have to replace Caps near the vertical or circuit.thank you
Nov 23, 2009 | JVC AV-32950 TV
NO PICTURE BLACK SCREEN AND A BLUE LINE ACROSS SCREEN.
The vertical circuit has failed. This can be as simple as poor connections on the pins of the vertical IC or a defective IC. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide details and instructions.
Dan
Apr 01, 2009 | RCA TruFlat 27F520T 27" TV
Picture screen
Hello! You have vertical collapse. There are bad solder connections at the vertical output IC. I have repaired MANY panasonic tv's like this. Very easy to repair if you have any soldering experience. If soldering does not fix the problem you need to replace the vertical IC. Good luck
barneyluc
Oct 06, 2008 | Televison & Video
Plasma screen
this plasma TV repair site might have the fix if the lines are black thick ones. bad circuit joints that might need to be re-soldered.
Jul 24, 2008 | Samsung PPM42S3 42 in. Plasma Television
One White Horizontal line on black screen
replace the vertical IC problem solved
Dec 31, 2007 | Sanyo DS25390 TV
VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Vertical black lines on my Thomson 42" Plasma
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Sep 05, 2007 | Televison & Video
did you fix the black line? please let me know as my TV (same model) has the same problem.
Jul 14, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
