Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
RYOBI LAWN HORNET MKIII- SPARK PLUG
what spark plug should I get? Could not find a model No- but did find the following info on engine-
ENGINE FAMILY-SN 4031UB24RA;EA
DATE CODE-608
171A3453(95)
608-1209059
Any iddea?
  • 36 Answers
You should find its a DJ7Y Champion Spark Plug
Marc
Posted on Apr 16, 2009
  • Marc Buck
    Marc Buck Apr 16, 2009
    The gap is 0.6mm
The spark plug is Champion DJ8J. I am not positive of the gap setting. I replaced it with a Diamond Fire E3.16.
Does it have a fuel filter and air cleaner?
Since you don't answer yet, I would say "RJ19LM", I'm sur at 90%, but you have verify this info.
Ghislain
Posted on May 16, 2008
No spark on plug
Posted on Apr 11, 2008
I have Ryobi Weed Hornet Model RWH1100A MKIII and the primer bulb has disintegrated. I'm told spare parts are not available as this model is not made any more. Is there any way I can bypass the pr
The primer only pulls fuel from the carb, into the bulb and dumps back to tank, this is a starting aid so there is always fresh fuel in the carb, you can just blank of the pipe from the carb to the primer, this will just turn it into a standaed non primer carb, if it starts ok just useing the hoke then leave that way
Mar 14, 2012 | Garden
Needs carby ajusting for ryobi lawn hornet 70 about 15 years old but has been great
Hi duthie20, the low speed(closest to engine block) should be 1 and a quarter the high speed 1 and a half(the other one). That should get ya going, you may have to tweek these adjustments a little eigther way. Happy New Year!
Dec 28, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
How do you take off the clutch off a RYOBI lawn hornet mk3
You have to hold the engine from turning, somehow. If you get it held firmly, then you have to give the clutch a rap with something to loosen it. I use a piece of hardwood and a hammer. Make sure it is being driven counterclockwise. All you have to do is get it loose, once you do, you can remove it with your hands.How to keep the engine from turning? Some suggest using a bolt threaded the same as the spark plug, turn it in past the top of the cylinder. Now turn the engine over easy until the piston touches the bolt. Now is when to rap the clutch with the wood/hammer. Good luck...Lee
Oct 08, 2009 | Ryobi Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,144 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
John Wilson
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
