Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos LC46D64U, problems with av input video signal
I have a 3 month old aquos 46d64u LCD TV which is having a weird problem with the standard av inputs. Occasionally when turning on a gaming system (Wii and XBox), the audio will come through fine, but the video will just be a series of random colored patterns that flash on the screen. Both systems produced the same garble pattern, but through different av ports.
This has happened twice, and the second time turning the TV off and back on resolved the issue (don't know what fixed it the first time, tried too many things without knowing which one worked).
Both times this happened, one of the consoles was left on accidentally for a few hours, while the set was on another input. Could this have been the cause?
  • Rrilltrae Mar 14, 2008
    Will do, but it hasn't happened since I posted.
    The thing I found so strange was that the second time, I attempted to turn both systems on to figure out what was going on, and they both produced the exact same pattern on different av ports. This pattern was different than the first time, but similar.
    I've seen plenty of console garble over the years, but never had two completely different systems produce the exact same errors
  • jedikn1te May 11, 2010
    Hard to say if it's an intermittent problem. Next time it happens, could you post up a picture of the problem?
    Sniper:
  • 53 Answers
You know, I've had two repair instances regarding this particular model line (D64U) where there were problems with only the analog inputs (such as the component/composite).... but with no problem with the HDMI inputs.
Replacing the Main Board fixed these TV's. Since both the Xbox and the Wii present the same problem on two separate inputs, this leads me to believe you most likely have a defective Main Board. If your TV is still under warranty, I suggest calling Sharp to locate your local authorized service center.
Posted on Mar 18, 2008
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos E203 No Broadcast now
My LC46D64U just started doung the same thing for any over the air channel that starts with 6. It cuts out for a few seconds about every 60 seconds. Has anyone found a solution for this?
Jun 17, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Signal is not compatible with this input when i connect my laptop
If the screen resolution on your laptop is to high or not supported by the TV, that is the usual error message.  I'm not sure what video output you are using but if it's the common S-video output, high resolutions will not be supported through it so maybe try a lower resolution and work your way up until you get the message again.  Then you will know the threshold.
Mar 26, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos Audio Intermittent
This is a problem with the ATSC channel's reception. Usually switching to another channel and back solves the problem.
Jul 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
571 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
