Avid Xpress Pro Logo
Anonymous Posted on Mar 20, 2010
Can Avid Xpress Pro be installed on windows vista?
Can Avid Xpress Pro be installed on a windows vista home edition? I bought this program and installed it but when I launch it, it asks for a dongle key. What should I do?
Level 3:
  • Master 6,688 Answers
  • Posted on Mar 20, 2010
Cindy  Wells
Master
Level 3:
Answers
6688
Questions
0
Helped
3532966
Points
21745
According to the manufacturer's spec, version 5.8 is not supported for Vista. It also requires a FireWire port ( 1394). The application key (dongle) is shipped in the box for legally obtained (first-buyer) software. If you didn't get the dongle, you will need to contact the manufacturer.
http://www.avid.com/products/1906.htm
The software will not work without the key. (Personally, I avoid such software since dongles get lost or damaged.)
I wish that I could be of more help.
Testimonial: "Thanks Cindy I've seen the key and it's now working."
2answers
Does Avid Liquid 7 support Vista Home Premium
Avid Liquid 7 is an video editing and authoring software created by Pinnacle Systems.Though they have mentioned support for only Windows XP, it is possible to use Avid Liquid 7 on Windows Vista and Windows 7. Tip is very simple. You just need to run it under compatibility mode. To do this
  • Right Chick on Avid Liquid 7 Shortcut
  • Open file location
  • Right Click on exe file
  • Properties
  • Click compatibility tab
  • Tick mark 'Run this program in compatibility mode' and choose Windows XP (Service Pack 2)
  • Apply and run the software.
tip
Mac Sony HDR-SR11 MTS to Avid converter-Convert AVHCD to Avid I have Sony...
I have Sony HDR-SR11 AVCHD HDD camera to shoot family videos and beach videos. However, after I transfer .mts files from Sony HDR-SR11, Avid does not support the AVCHD file. I wonder the best AVCHD workflow into Avid from Sony HDR-SR11 and google for solutions.
I was recommended with Sorenson Squeeze to convert Sony HDR-SR11 MTS to Avid DNxHD codec. However, Sorenson Squeeze does not natively support .mts and the file extension should be changed to .m2ts. The conversion time is much longer than that the original clip. One thing should be mentioned is that the exported DNxHD is loaded quickly to Avid. Sorenson Squeeze also costs quite a lot. I just find a better Mac Sony HDR-SR11 MTS to Avid converter - Aunsoft MTS/M2TS Converter for Mac. The price is dramatically low comparing to Sorenson Squeeze, and the output MOV video works in Avid MC and Xpress Pro.
Here is how I import Sony HDR-SR11 camera videos to Avid Media Composer by converting 1920x1080 MTS to HD MOV.
Step 1. Load Sony HDR-SR11 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR11 MTS to Avid converter on Mac Snow Leopard, and click the "Add" button to load HD .mts videos.
Step 2. Choose AVC MOV for Avid.
Click the "Format" option, and choose Adobe Premiere/Sony Vegas > MOV (AVC)(*.mov), and the Sony MTS to Avid converter will transcode the HD MTS files to MOV for Avid MC, Xpress Pro.
Step 3. Convert Sony HDR-SR11 AVCHD to Avid.
Click the convert button under the preview window, and the Sony MTS to Avid Converter will start converting HDR-SR11 AVCHD MTS to HD MOV for Avid Xpress Pro, or the upgraded Media Composer 5.
As soon as the conversion in finished, you can import Sony HDR-SR11 videos to Avid Media Composer, Avid Xpress Pro for editing. The output HD MOV also works in Final Cut Pro and iMovie, and other non-linear editing software like Adobe Premiere on Mac OS X.
If you are using other Sony AVCHD cameras, you may also face the same problem. Have a look at the Sony HD camcorder page for Sony HDR-XR520, HDR-CX110, DSC-TX7, HDR-TG7 and other models.
on Jul 26, 2010 • Cameras
Hello, my problem is like this - i installed Avid xpress pro for mac and starting the program it says that fails to find a dongle for it. I have not found the "rainbow.iokit.sentinel" driver in the kext...
If your buy legit copy of that program, it comes with a dongle. It is for copy protection . Program only works if it see that dongle plugged into computer. This way purchased program can be run only on one computer at any given time no matter on how many computers is installed on.
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
No video comes into AVID express pro only audio with capture
The problem was with the Mojo. I disconnected the power supply then reconnected it and it solved the problem. Thanks for your reply.
Avid Xpress Pro 4.3 says exception thread message not received when i try to capture
i got the following message:
Exception: DIOProducerCV: Thread message not received.
After uninstalling the last Quicktime update it worked fine again.
Strangely Avid advised me "strongly" to install Quicktime before the error occured.
greetz.. dc
1helpful
Avid editing system error
Check the level of your black burst (Reference) input. We had this error on our Adrenaline and discovered a low black burst level was causing it.
Avid Xpress Pro - AVID crashes when deck is turned on
This sounds like a fatal error out side of avid settings, you're going to need to do an avid reinstall to replace any currupted files. Just back up your media capture and .bin / avb files. Does xpress let you create an omfi file just import that rather than relinking?
Top Avid Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
