Question about HP Compaq nc6320 Notebook
HP LAPTOP NC6320 wireless not working
After reformating my laptop with a win xp pro i can't connect to the internet because my wireless is not working and i can't seem to find it anywhere on my computer to turn it back on, my bluetooth is also not working and my computer wont let me stand by either.
  • mcrudo Dec 31, 2008
    same issue, however, it's with an installation of gOS space...anyone know how to get the wireless device functioning after clean wipe of win2k and reinstall of gOS (unbuntu variation)?  device will not turn on (no blue light).  had no issues with a same reinstall on a compaq nc4200
    New Friend:
  • 4 Answers
Try to get to another computer to access hp website. Download all the nc6320 drivers onto a CD or USB stick. This will take some time as there are a lot of them! Each one needs to be installed separately but each one will run from the CD or USB device. (If your hard drive is not Drive C, then remember to install each driver to the same drive as your operating system. You get a chance to do this each time you install a driver.)
Posted on Aug 10, 2012
    Genius:
  • 3,587 Answers
Hmm..sounds like an unhappy device.
the wireless is under control panel, wireless setup..
if it's not there, go to network connections, and see if it's there, and if so, enable or repair the connections
as to the stand by..take care of that later..it's in control panel, display, settings or screen saver,
check your computers warranty here 4 FREE
Posted on Mar 11, 2008
  • 520 Answers
Dont bother looking its not there.
when u reinstall windows system doesnt recognise wifi so you have to manually install drivers before system knows that they are even fitted.once the drivers are installed windows will detect new device and install.
go to hp site and navigate to ur model drivers ;if you cant find site let me know
Posted on Mar 24, 2008
SOURCE:
I have configured my d link router and able to connect it with my win xp laptop and after i connect internet cable to the wireless router i am unable to access the internet through my win xp and win 7...
If initially the Win XP laptop was connected to internet at the cable/dsl modem, its MAC address would have been registered on service setup. If the router is now in place between the Win XP laptop and the cable/dsl modem, you would need to go on the Win XP laptop and log into the router as admin to clone the Win XP laptop's MAC address to the dlink router's WAN interface (internet facing side) so that the cable/dsl modem will see the previously registered MAC address and will enable the internet access.
Mar 23, 2011 | IBM Computers & Internet
Dell Inspiron 2200; Win XP pro; detect router but no connect
Have you change settings on your router? if not try to disconnect and reconnect your dell computer. if still not working. turn off both laptop, turn off the router and modem. wait for 10-20 seconds then turn on the modem first, and if the modem is stable, turn on the router, and if it is stable, turn on the dell computer and try to connect. If still fails, try to delete wireless profile adn recreate it. If still fails, check device manger if there is a problem in your wireless driver. If still cannot connect, perform system restore.
Apr 04, 2010 | Dell Inspiron 2200 Notebook
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Toshiba A205-S5819 Can't connect to wireless internet
The router you're trying to acess may not be set up for Vista or may not be compatible with Vista. I had to upgrade the router at my shop in order to work on Vista OS machines.
Jul 20, 2008 | Toshiba Satellite A205-S4617 Notebook
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Wireless Network Driver
Dezzie.
This software will work with your Toshiba Laptop. This software was created by Toshiba. You need to install the Network Adapter. So go to Toshiba's website and update your network adapter drivers for win XP SP2.
Please let me know how this works.
Thank you
Cabletech
Nov 22, 2007 | Computers & Internet
HP Compaq nc6320 Notebook Logo
2,815 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
