Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD52525 DLP TV
Lamp lights for a couple seconds then goes out and red lamp light comes on. New lamp does the same thing. Screen never lights up. I've heard bad capacitors will do this and was trying to locate them in my TV but not sure of the access to the correct board. Any advice?
Scott
  • adschweda Dec 24, 2008
    we replaced the bulb but the red light is still on... anything else we can do?
    Genius:
  • 1,153 Answers
Yes, this can happen and there also are fuses that needs to be changed(F9A09) and caps C9A37,38
Posted on Mar 11, 2008
6ya staff
SOURCE:
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
Jan 03, 2015 | Mitsubishi WD65737 65" DLP TV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I just set up a new Mitsubishi projection TV (WD60C9). When I turn it on, the green light flashes for about 20 seconds, then the welcome screen appears for about 2 seconds, and then goes blank. The light...
Its possible that the lamp was damaged in transit or perhaps it was just faulty from the word go, if you have only just purchased the tv unit i recommend getting in contact with the retailer as the tv should have a working lamp upon purchase. I hope this helps you. Good luck.
Dec 02, 2009 | Mitsubishi WD-60C9 60" DLP HDTV
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
I have a mitsubishi WD-52525 DLP Tv; I replaced the lamp, powered on the system, I hear the fan go on, the green wait light goes solid after a few seconds and a few minutes later the lamp light goes solid...
Chances are the lamp is not bad. Is the lamp door reseated properly? The is an interlock on that door that must be activated in order for the set to turn on. If the unit was woking before the lamp went out this may be the problem
Nov 26, 2008 | Televison & Video
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
