Question about Maytag MER6772 Gemini Electric Kitchen Range
GE oven range showing F9 fault code and beeps annoyingly
This just happened while my wife was baking then it just turned off and showed the code and started beeping. I tried turning it off from the main switch(circuit breaker) for about an hour then turned it back on but its not helping. Hope you can help tnks.
    President:
  • Maytag Master
  • 2,651 Answers
Problem is listed as a door lock/latch issue check wiring to the door lock assy(which is usually fine) generaaly requires replacing the self clean latch assy
Posted on Mar 11, 2008
SOURCE:
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Kenmore gas range will not stop beeping showing F9 in window
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%^
Apr 03, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
Wife was trying to clean (self cleaning oven) and after setting timer the oven door will not lock and it will now not let us do anything now and it shows a f9 code and when i press bake control, dr shows...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^&^%^%
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
190 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
