Centrex plasma tv model ctpl42s5
Will not start up power ok led on sub power board flashes 3times every 3seconds
Centrex plasma tv model ctpl42s5 same problem wont turn on have extended warranty, what can we do.
Posted on Apr 14, 2008
Centrex plasma tv
that means your control board is really unhappy..can you turn it off, for ten minutes, and see if is still the same?
Mar 11, 2008 | Televison & Video
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 11, 2011 | Samsung PS42B430 42 in. Plasma TV
Error code 11 flashes model TCP50VT25
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Sanyo DP42746 42 in. Plasma No Video
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Apr 12, 2008 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
