PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Acer Crystal Eye Web Cam
By rainbovan on Mar 11, 2008
I haven't touched a single setting in my computer but I went to connect to a web conversation and my computer simply says "Camera not found". Its not even there in the hardware. What may have happened and how do I fix it?
5720z
Same Problem
Apr 16, 2009
-   ok the solution for this problem is as follows..
1. right click on my computer
2. select manage
3. go to device manager
4. find "usb composite device"
5. right click "usb composite device"
6. select enable
7. now test it with your favourite software or using the acer crystal
software to see how beautifully its working :) -   Guest
Mar 27, 2009
-   problm no mensenger -   mariotome200
Jan 17, 2009
-   My camera was working great one day and then the next it waS SAYIN that it was no longer detected! i really want it to work again but its not! HELP ME! -   luvleelyfe
May 15, 2008
-   my cam not instol my cam in iaptop acer 5630 wlmi
pls give me program i need instol pls
thanks
-   medo2007
Best Solution
posted on Mar 11, 2008
Very Helpful)
Jekkyz
Rank: Wiz
Rating: 77%, 23 votes
try reinstalling your camera driver
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 06, 2009
Not Rated)
firepaladden
Rank: Apprentice
Rating: 0%, 0 votes
I’ve faced with this problem on changing my preinstalled Win XP Home to XP Professional.
Well, as you know Asus do not provide separate driver for camera. It can be explained very simple - it does not exist at all as separate driver/package.
To install your camera under Win XP you should have SP2 or SP3 installed (I’ve done it with SP3).
Here are steps to do it:
1) Check in Eee PC BIOS that the device is ENABLED
2) When Windows XP SP3 is started just call ‘Computer Management’ (right click on your ‘My Computer’)
3) Switch to ‘Device Manager’
4) Find you Camera 2.0 device there (it will be displayed as device with errors if it is enabled in Eee PC BIOS)
5) Right click on that device and call ‘Update Driver’ from pop-up menu
6) On this moment ‘Hardware Update Wizard’ should be displayed for Camera 2.0 device
7) Choose ‘Install the software automatically’ (Recommended) option
8) Driver will be retrieved from windows folder and installed.
Well, If all is ok your camera should be installed without any problems and will appear in Windows Explorer devices list.
Note: If found this by myself and it works for me. In case if you haven’t succeeded with camera install you can try to select an option to find suitable driver automatically via Internet (in ‘Hardware Update Wizard’).
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how loose the keyboard, some of the keys stick!!
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
the volume on pc is turned up but I cant get the mute button to deactivate. stays lit red when I... (More)
Answer
Ibm thinkpad shuts off when I plug in charger..how do I change fan settings?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
