SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: clock and light in oven work but stove and burners will not
Sounds like the wires connecting your control panel to the individual heating elements have either shorted out or been disconnected. Try taking off the control panel board and testing the connections (the four on the sides of the circuit board in the middle, and the two five pin and one three pin connector on the mainboard). If they are good, then your problem lies in the control board itself and will require a replacement from Whirlpool. Depending on if you have the touch sensor board or a push switch, it can run upwards of a few hundred bucks.
SOURCE: I have a GE True Temp XL44 oven the stove burners
Service manual.
Probably the ignitor. Even if you can see it glow it might not be strong enough to open the safety valve. Here is: how it works
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
SOURCE: I have a 17 year old Ge double oven electricI have
Sorry to read about your problem, I hope this helps you out.
Unless you are knowledgeable, on range repair, I suggest you call a service company.
you may have a bad control knob. defective socket or broken wire.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
