Touchy Sound The sound to right earphone randomly cuts out and returns, though it always seems longer when its gone, there are no nicks, cuts, or major stress points on the cables. This happens when used with any device I've tried; laptop, iriver, and an ipod. These are less than 6 months old. Thanks.
1. this could be several reason why the sound cut out when using skype 2. check the hard drive capacity 3. you may need more RAM ( random access memory). If you are at minimum this may not be enough to complete the VOIP ( voice over IP) 4. this could be the connection with the skype recipient. 5.check your skype settings 6.check the sound card in your laptop ( drivers etc) 7. check the speakers of the laptop the may be malfunctioning or the earphones if used.
open it up completely...where the charging socket is at the bottom use a toothbrush and some alcahol ...theres dust and fluff shorting out the pins inside ....had this problem before...if you plug in an earphone(handsfree) it should work...
Try pressing the sound up button on the top of the keyborad. There are 3 buttons sound up, sound down and mute. It appears that the sound control on windows is independant of the buttons.
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
If you looked for dry connections and found none, there is probably a componet that is intermittant, and these can be tough puppies to troubleshoot, without monitoring the power supply voltages and sittinfg with the unit.
Have the volume control to be repaired, they a cellphone repair shop. If they can't... suggest to bypass the volume controls to its maximum control and buy an earphone that has volume control on it.
sound one one side cuts out randomly
