Question about Canon i9900 InkJet Photo Printer
To much red printing
My i9900 is printing with too much red showing throughout the picture. Shadows show as dark red.
  • Anonymous Nov 15, 2008
    I have the same problem, except with green. It happens even when I use a different computer, so it is a printer problem of some sort....
  • jimnealey484 Apr 03, 2009
    I have the same problem, to much green, but only on large prints ( 13x19 ) What causes this?
One of my ink cart. had tape over the vent hole (Photo Megenta) which caused it to print to much green.
Posted on Apr 03, 2009
    Genius:
  • 3,587 Answers
Is that the case with test page, too? sounds like a color transform issue from your photo application to the printer..
Posted on Mar 11, 2008
I have a 65731 HD DLP and when I turn it on and start watching a light scene it works great... until a show has a dark scene, like rain or low lighted scene. it appers to look blue or red shadows on...
hi,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
May 25, 2010 | Mitsubishi WD-65731 65" HDTV
Was printing photos all was ok then printer stoped printing black
There are 4 inks, cyan, magenta, yellow, and black. When the black runs out, you are left with sort of a dark purple or brown color.
Oct 03, 2009 | Canon I900D InkJet Photo Printer
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
TV showing Red shadows when viewing the picture
Open the TV set and at the end of the CRT, there is a Circuit board (Video baord) where color adjustments are manually done there. OK, normally there are cracks or cold solders on the terminal of the components which can be the cause. You'll need a technician to do the re-soldering of the terminals. cheers.
Oct 31, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Canon i9900 InkJet Photo Printer Logo
208 people viewed this question
old marine
old marine
