Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Battery location need to reset bios password. can't find battery location on a zv5227 hp laptop? I am in need of a clip that normally comes with the motherboard that secures the keyboard cable in place. I have a new keyboard, but no way to fasten it securely in place. Any ideas or suggestions? The clip is a small peice of plastic the the end broke off of when it was removed the second time.
  • tunesntans Mar 11, 2008
    Thanks. The clip is really the biggest part of the problem right now since I have no funtioning keyboard without it.
    Genius:
  • 3,587 Answers
Hmmm..those are truly hard to find, the clips...
also, the bios password can be accessed on startup by using F2, then you'll see that option inside the bios setup.
those batteries are usually inside, under the bottom plastic panel. some others are under the palm rest, either way, you need to open up the whole unit.
Posted on Mar 11, 2008
SOURCE:
BIOS password reset
The only way to reset a bios password is to remove the CMOS battery. This is a watch type battery, normally model 2032. Not sure where it is located, but is normally underneath the keyboard, connected directly to the motherboard. Can be a pain to get to.
Jan 28, 2014 | Acer ASPIRE 4720Z-2A0508MI LAPTOP LCD...
BIOS PASSWORD REMOVAL FOR HP 620
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and Documents. Once you find them search for Bios Password or Reset Bios Password.
Apr 07, 2012 | HP Computers & Internet
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
My Hp compaq 6515b is not recognising my power password any suggestion.
1st method identfy bios when start up " AWARD BIOS, AMI BIOS,etc etc below some backdoor passwords try these first
Award BIOS' :
AWARD_SW, j262, HLT ,SER,SKY_FOX,BIOSTAR,ALFAROME,Lkwpeter,j256,
AWARD?SW,LKWPETER,syxz,ALLy,589589,589721,awkward,CONCAT,d8on,CONDO,j64,
szyx.
For AMI BIOS' try these backdoor passwords:
AMI,BIOS,PASSWORD,HEWITT RAND,AMI?SW,AMI_SW,LKWPETER,A.M.I.,CONDO.
For PHOENIX BIOS' try this backdoor password:
phoenix
2nd method: remove the laptop battery, and in back of your laptop 3 to 4 screws showing small keybord pictured or keyboard mark, remove those screw's, turn front and 3 little hidden clips upside of keyboard, slide down those clips, carefully remove the keyboard, in motherborad near touchpad, locate the small silver color coin battery, remove that battery for 1 minite or 2. and put it back. your password will reset. and also bios resets to factory setting.( before resetting just write down the setting on paper) best of luck keep smiling. aaarwind
Jan 15, 2011 | HP Compaq 6515b Notebook
I FORGET MY LAPTOP BIOS PASSWORD WHAT CAN I DO I HAVE HP COMPAQ 610
i,
To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Dec 27, 2010 | HP Compaq Motherboard
How to reset laptop compaq nx6325 bios password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Nov 30, 2010 | HP Compaq nx6325 Notebook
Hi, how can i reset BIOS password, notebook Gateway MT6705?
According to Gateway, there is no easy way to change the password. You need to contact Gateway Customer Services and ask for assistance.
Dec 17, 2009 | Gateway MT6705 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
It is the power on password that I need it ownt
Its the Bios password...if u don't remember the bios password...u won't able to do anything...Bios password can be reset my removing the c-mos battery...it's a small battery located in motherboard...
Jul 12, 2009 | HP Compaq Evo Notebook N600c
Battery location
You would have to totally rip apart the laptop to get to it, and on some HP models the batteries are soldered on. Also, on some modern laptops pulling the CMOS battery won't reset the password anyways.
A more effective solution is to call hp and tell them you need to reset the BIOS password on your laptop. You will have to provide them a proof of purchase for the product. After you provide that (usually fax or scan of receipt ) they will give you instructions on how to reset it.
Nov 09, 2007 | HP (5185-6477) Motherboard
Open Questions:
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
