Try letting some water through the valve by holding the handle up and then snapping it shut. There may be some dirt under the seat of the valve.
Otherwise the vlave is leaking because the water is either to hot or there is too much pressure in the tank.
In some cities the pressure of the water supply is too high and with the expansion of the water, it creates too much pressure in the tank. An expansion tank will need to be installed near the water heater.
You may also just have gotten a bad vlave.
Heatman101
SOURCE: temperature & pressure relieve valve leaking
Once in a while flicking the little handle will reseat the valve or release whatever dirt is under it. Usually not...
Your best bet is to replace it.
Turn off your hot water heater and drain the water down past the valve. It jusr screws out and the new one will screw back in.
You can find a new valve at any hardware, HomeDepot or Lowe's they are not exspensive at at.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
SOURCE: why does the t&p valve leak on a new water
T&P valves are designed to release with excess pressure or high temps. But it is not uncommon to get a faulty one. If that is the case, it is fairly easy to replace. If the water heater is new, the vender where you purchased it may be willing to give you a new t&p. Otherwise they are usualy around $10 to $15. Hope this helps.
