My samsung washing machine J845 recently has been broken. The last time we were using it the electricity went down , after it went back on we open the power of the washing machine but there was nothing happened. Please help us to solve it. Thanks
  • khoa_tianh Mar 11, 2008
    yep there is power out of the wall socket, but there is no power in the washing machine. Thanks
  • Anonymous Mar 08, 2009
    Do you know where the fuses are? Looks like circuit breakers but no fuse
    Genius:
  • 3,587 Answers
Perhaps it's the circuit breaker on the wall panel? do you have power out of the wall socket?
Posted on Mar 11, 2008
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    ok..that's a good thing..there are a few fuses on the control board..they may have popped..open up the top panel, and inspect them, with power off..unplugged from wall, that is..
    when power comes back on, it's a spike that can exceed the ratings of the fuses.
The door of our J845 wont open. its been 3 hours since the cycle finished
hawe you disconected from electriciti or no. pull door inside- if not helping - time switch is faulty.
Mar 18, 2011 | Samsung WF203ANW Front Load Washer
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Samsung J845 washing machine will not spin.
could be the dampers have failed or the drum mount is broken, try a spin with no clothes, if it is spinning with noise or the drum is not running true it will need major repairs.
Apr 19, 2010 | Washing Machines
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Door jammed shut
normaly this is due to water still in the drum
Sep 20, 2009 | Washing Machines
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
J845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 11, 2009 | Samsung Washing Machines
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Washing Machines Logo
314 people viewed this question
Top Washing Machines Experts
