Question about Sony Handycam DCR-TRV25 Mini DV Digital Camcorder
Jammed tape the error code C32:11 comes on when we turn on the camera and the tape seems jammed and will not come out. It seems like the last time the tape was put in it didnt go down all the way.
  • 1 more comment
  • Anonymous Jul 12, 2008
    Same Camera same issue.  Anyone have a solution?  Thanks big Big!!!
  • petesarus Aug 26, 2008
    same thing here-- have tried the "smack it on the (right) side" trick. this is documented on some websites but it seems like it works sometimes and only as a temporary fix. tape is still stuck and rewind creates an error C:31:23
    anyone?
  • validae May 11, 2010
    Your problem is that the rewinding wheel is not moving.Look carefully inside the mechanism, maybe is something stuck on it
I am having a similar problem but my code is C:31:23 does anybody know exactly what the error is for this code?
Thanks,
Gregg
Posted on Jun 22, 2008
6ya staff
SOURCE:
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Error 1 keeps coming up on display. Batteries are new, jam cleared from cutter area. No other jams. Why won't it clear?
I had the same problem. My batteries were fine, there was no tape jam, and I also cleaned the writing head with the DRY tool that comes with the label printer (you find it in the tape box). I opened the casing, checked the motor, etc. but nothing seemed to help. My last recourse was then to GENTLY clean the writing head by taking a lens cloth and putting some alcohol on the cloth. WOW! That worked!! Brief summary: Take a lens cloth or the tool that comes with the label printer and put some alcohol on it. Then GENTLY clean the writing head. I hope it works in your case, too!
Jan 20, 2012 | Dymo LetraTag QX50 Thermal Label Printer
The tape runs for 3 seconds then error message ''please re-insert cassette / on screen error code C:32:22 - head cleaner tape has the same effect
When I got this error I removed the battery for 10 seconds and then put it back in. Camera should come on automatically. I just did this to mine and it seems to work.
Oct 03, 2009 | Sony Video Cameras
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
DCR-HC42
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Sep 19, 2007 | Sony Handycam CCD-TRV608 Camcorder
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-TRV25 Mini DV Digital Camcorder Logo
271 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
