Question about Toshiba Satellite A135 Notebook
Security Password How do I clear the security password?
  • cris_011 Mar 11, 2008
    start up password
    How to remove start up password?
    Genius:
  • 3,587 Answers
Admin or applications level? admin is in F2 during start up, but you'll need to know the main admin password to do it.
applications are unique, and you may not be able to do that unless you re install them.
check your computers warranty here 4 FREE
Posted on Mar 11, 2008
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    hmm..do you know the existing one? if so, log on, then go to control panel, users, and then modify password, by entering old one, then leaving the new field blank
SOURCE:
My x-tigis1501 forgotten password
Go into Settings and then Security. Select Clear Security Credentials. Now try again to set up a new password lock. If you are still getting interference then put your phone into Recovery Mode and select Wipe Cache Partition and Clear Dalvik Cache. You may not be exiting the application properly or missing a step to save your password. Since you are experiencing problems with the lock function it may be best to avoid it completely.
Dec 07, 2016 | Computers & Internet
Galaxy 6. How can I bypass password?
Samsung Galaxy S6: How to bypass Password:
Hello. You'll need to enter in your password first in order to get into the phone, and then set the phone to no security so that you can get into your device without having to enter it all the time, if it has become annoying. I would suggest at least using a simple swipe pattern to lock your phone
1. Enter screen unlock password
2. Go to:
Settings>Device>Lock screen>
(under screen security)
tap on "Screen Lock"
(enter your screen unlock password to confirm)
select: None, or Swipe, or pattern
if you are unable to select: None or Swipe
because they are greyed out
like this:
bypass-password-galaxy-6-kyzl0pi20tqzz121bvlihxv0-2-0.jpg then you will have to just clear the credentials in security..
(this happens when you select a high security option)
go to:
Settings>Security>Clear Credentials
then go back to
selecting your new lock screen option
then, Go to:
(enter your last screen unlock password to confirm)
Feb 12, 2016 | Samsung Galaxy Cell Phones
Acer P1265 projector asking for password
Security
This projector provides a useful security function for the
administrator to manage usage of the projector .
Press to change the "Security" setting. If the security function
is enabled, your must enter the "Administrator Password" first
before changing the security settings.
• Select "On" to enable the security function. The user has to
enter a password to operate the projector. Please refer to the
"User Password" section for details.
• If "Off" is selected, then the user can turn on the projector
without password.
Feb 06, 2012 | Acer P1265 DLP Projector
I have forgotten the password for my Belkin router serial number F5D7230-4 can someone help me with this? I need to be helped in simple terms please
In order to check the wireless security password of your Belkin wireless router , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page .
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can change or check your password
Good Luck!
Thanks in Advance!
With Regards,
Prema
Jan 07, 2011 | Belkin (F5D7230-4) Router (587009)
How to change password
I got your issue, Inorder to change the password for your Belkin basic wireless router, please follow these steps.
1. Open Internet explorer in the computer which is online using computer wired with the router (eg: your wired comp)
2. Clear the address box in the internet explorer and type in http:\\192.168.2.1 and hit enter, you will log into the Belkin router setup page
3. In the left hand side column under the heading Wireless click on SECURITY .
4. It will ask for login password, Leave the password as blank and click on submit
5. It will show the security mode as WPA-WPA2 (Personal PSK) uncheck the box which says pre-shared key you will see the default password, clear that and type your own password, (It must be atleast 8char and its case sensitive)
Good Luck!
Thanks in Advance!
Regards,
Prema
Dec 29, 2010 | Belkin Basic Wireless Router
What is the original password for wing mobile???
Tap the "Start" button, followed by "Settings."
Tap "Security" or "Personal tab," followed by "Device Lock" or "Lock."
Enter your existing password when prompted.
Enter the default password in the "Password" box. Refer to your phone's user's manual to retrieve the default code. The most common default codes are "1234," "0000" or the last four digits of your cell phone number.
Re-enter the default password again to confirm your entry, and then create a hint to help you retrieve the password in the future in case you forget it.
Tap the "OK" button to complete the process.
Hard Reset Tap the "Start" button, followed by "Settings." Tap "Security" and click the "System" tab. Locate and click "Clear Storage." Enter the security code when prompted. Tap "OK" to confirm your decision to perform a hard reset. Wait for the phone to restart.
Thanks for rating
Dec 24, 2010 | T-Mobile Wing™ Smartphone
I have lost the security password in my ibm thinkpad t40
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Jun 26, 2009 | IBM ThinkPad T40 2373 Notebook
Error Message at Startup
Ok at boot up press F1 to enter bios, when loaded select the following sequence of headings
1. Security
2. Security Chip
3. Clear Security Chip
That should solve the problem
Apr 16, 2009 | Computers & Internet
How to unlock my security code
ranjithnairv + hardknox - press the menu key in the middle of the keypad, scroll to initial setup then select either master clear or reset and enter the 000000 as the security default codes.
all others take the phone to a mobile service center and have them reset the phone codes back to the originals for you.
Nov 20, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Password settings
if you are talking about wireless security, you will find the settings under Wireless Security in the routers setup page.  The default will be HTTP://192.168.1.1  no username, default password of "admin"  If you are talking about the router's password itself, you will find that under Administration in the same setup page.
Oct 19, 2007 | Linksys Wireless-G Broadband Router
Toshiba Satellite A135 Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
