Back to:
Tags:
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer
Brother Multifunction Inkjet MFC-210C Reset... (by 3 users)
posted by Sighkick on Mar 11, 2008
The LCD is displaying 'Unable to Clean' and the Troubleshooting Guide suggests that there is something jamming the works.
I have carefully checked the machine [bit of a tech myself] and there is nothing to dislodge.
The Brother website suggests sending the unit for repair.
Does anyone know the procedure to reset these printers? Usually this involves holding down a sequence of keys whilst plugging in the power. The service agents do not share this as its a simple way to gain revenue.
Your help would be appreciated. Sending it for repair is out of the question as the value is only in the ink cartridges.
Comment by Sighkick, posted on Mar 11, 2008
Hi Mix-it-up,
Your solution goes part way to solve the problem but I always end up with Machine Error 46 with all four buttons [Photo Capture, Copy, Fax, Scan] flashing green. Can you continue to offer possible solutions?
I was surprised to actually get a reply from Brother which also shows Error 46. Here is their solution which didn't help me but may be worth while for your database of solutions:
"Please do according to what we advise in the following:-
Take the power off on the back of machine ---> Holding down the Menu/Set button (Don’t release) and take the power back in at the same time ---> Releasing Menu/Set button till MAITENANCE coming ---> Please type "82" and see what will be happen from LCD ---> Please report Error code or Error message to us
If Error "00" coming, please push Stop/Exit button to make the machine into MAINTENANCE MODE. Please type "99" when Maintenance coming from LCD. The machine will back to normal situation and report message showing on LCD to us".
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Oct 29, 2008
clean unable for brother mfc240c
Comment by doggie5, posted on Apr 01, 2008
change unable, clean unable. Troubleshooteing says" check connections (I did) they are O.K. check for ripped paper (I did) no ripped paper
HELP.
Best Solution
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi Mix-it-up,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Brother Multifunction Inkjet MFC-210C Reset Required:
I don't want to Accept this solution
Solution #2
Mix-it-up
Rank:Guru Guru
Rating: 88%, 1127 votes
press menu then start bk-copy then fourtimes arrow-up.
machine will be in maintenance mode.
press 8 then 0 (zero) and then several times til PURGE 96xx (not sure about digits). press 2-7-8-3 and then 9 -9 to leave maintenance.
You have to replace the waistink absorber, too! Without changing you will seriously demamge the machine!
Rating Locked! (?) Sighkick has rated this solution as Thanks for Trying
Thank You!
Can you Help with these Printers problems?
Brother Multi-Function Center MFC-240C...
I press "SCAN", Then Scan to file, Start...
I bought this printer refurbished from Staples about two...
my psp memory stick duo got stuck in the printer drive....
the printer will not stay online long enough to print i...
the printer will not stay online longer then 5 mins... and...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
