Fisher & Paykel 608 washing machine
The hot water intake was very slow, cold intake ok. Now both are very slow. Do the intake solenoids have a slow and fast position for spray rinse or fill? What is their operating voltage(s)
  • Anonymous Mar 16, 2014
    no water on main wash. solinoids are ok but theres no voltage feed at the main wash solenoid.
    Genius:
  • 3,587 Answers
Nope..the pressure needs to be maintained..I'm assuming you've checked for blockage in the line and cleaned the intake filters, right?
Posted on Mar 11, 2008
SOURCE:
Ecs gentle annie
Is it just the cold valve slow do you have a hot valve to swap it with to check the flow rate.
I think there 12volt valves,
The solenoids would be OK just the valve wont open all the way.
The solenoids do come off with a flat blade screwdriver under the solenoid.
Dec 17, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water not going into the machine.
The solenoids coils can be removed from the water valves.
Mar 30, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
My Fisher Paykel GWL 15 will only fill if Hot wash is selected. Should I call a service technician? Thanks Glenn
Try to swap the plugs and hoses to the hot /cold solenoids see if that works the hot valve with cold water if work you need to buy a cold valve.
Jan 24, 2012 | Fisher Paykel EcoSmart GWL15
Unable to wash using hot water -F & P Smart Drive 608 (GW608U)
Check that the valve behind the washer for the hot water is open, it will be labeled red and should indicate which way to turn to open it typically counterclockwise.
Dec 17, 2011 | Fisher and Paykel Fisher & Paykel Washer
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Limited water from cold solenoid
hi
if you select cold it should be only giving you cold water so the sensor should not be an issue , i would chang my hose over to the hot line and select hot ans see if that is ok if it is then it will be the solenoid you could try also swapping the hot and cold solenoid to see if that works
cheers grantreps
Sep 26, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
