Question about TruTech PLV16320 Television
Getting the TV to act as a PC monitor
I got the screen to work, but audio is not working. it will not play from the buil in speakers nor the speakers i plugged into the input labeled "audio" (located next to the PC=>Monitor input). I don't know what to do. help?
    Champion:
  • 367 Answers
Do you have the audio cord going from the green speaker output plug on the computer to the audio in plug on the TV?The volume on the TV needs to be up,as well as the little speaker icon in the lower right hand corner of the computer screen.I hope this helps.Thank You very much!
Tyler
Posted on Jun 17, 2008
Why won't my hp elitebook 8540p speakers work while in the docking station, connected only to external mouse and monitor?
You can switch audio playback between the docking station and your Surface speakers. Here's how:
Step 1: Swipe in from the right edge of the screen, and tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.) Step 2: In the search box, enter manage audio, and in the search results tap or click Manage audio devices. Step 3: Next, do one of the following:
  • To play audio through the audio port on the docking station, tap or click Speakers (CNXT Audio).
  • To play audio through the Surface speakers:
    • On Surface Pro 2 or Surface Pro 3, tap or click Speakers (Realtek High Definition Audio).
    • On Surface Pro, tap or click Speakers (2-High Definition Audio Device).
Step 4: Tap or click Set Default, and then tap or click OK.
http://globalvision.com.vn/vn/may-in-ma-vach-pc-3.htm
Apr 27, 2014 | HP EliteBook 6930p Notebook PC
No sound on PC, from external speakers - please help! :)
first thing you do is update your audio card or down load a software like(.driver identifier.) its free from google you will see an instruction to opereate that software
Feb 17, 2014 | Computers & Internet
I have a samaung pc/tv monitor,i use for pc and tv use,i have external speakers for the pc and would like to connect them also for the tv as the sound as is not very good,putting the tv menu in external...
Some actual model numbers would make this conversation more relevant.
If your PC speakers are self-powered they should accept the RCA output from any device that provides headphone or Line Level audio.
Where is the TV audio actually coming FROM? Maybe a Cable Box? THAT is where the PC speaker should tap in.
Many TV's have a Fixed or variable audio output. Fixed allows for disabing the TV speakers or turning its volume down without affecting the audio out to other devices.
Mar 13, 2011 | Audio Players & Recorders
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Need help getting audio to play on my HP 2009m monitor which is connected to my HP laptop.
The speakers on the monitor will work only when the sound output from the laptop is connected to the monitor speakers. Please make sure that you connect the cable from "Audio OUT" (generally Green colored port where you connect your headphone or external speakers) on the Laptop to the "Audio IN" port on the monitor.
Please let me know if it works.
Thanks and Regards,
Srinivas
Apr 21, 2009 | Computers & Internet
Problem with DELL 2408WFP
I have similar problem.  I'm using the HDMI connection from my PC to the monitor and when I connect my audio out from the monitor I get hissing and popping sounds along with the audio.  It sounds pathetic, I also hear the music and audio along with the hissing and popping.
If I connect the audio to the back of the PC the sound is crystal Clear.  I am using Vista 64 bit with NVIDIA GeForce 8600 GT video card.  Trying  to Google to see if others are are seeing the same problem.  I just got my monitor on Oct 6.
Sep 30, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Iiyama prolite e483s. no sound
Get a cable two male ends. Look for the female end on your screen. Put one male end into the port on on your screen and the other end into the port "AUDIO ONE" on your computer.
Try this it should work. The Multi-PIN cable is only for VIDEO, you need another cable for AUDIO.
Jan 27, 2008 | iiyama ProLite E481S-B 19" LCD Monitor
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
TruTech PLV16320 Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
