Question about HP Pavilion F1703 17" LCD Monitor
F1703 LCD goes blank after 1-2 seconds
Dave,
Got to the video board and "the 4 capacitors with coils around them" you refer to are actually "inductors" L701, L702, L751, an L752 and I checked conductivity through the solder joints and all is well. Any other ideas?
  • PAULFM Apr 03, 2008
    MY HP f1703 FLAT SCREEN IS BLANK, WHEN I SHUT DOWN AND RESTART, THE HP INSIGNIA FLASHES ON THE SCREEN THEN GOES BLANK AGAIN AND STAYS BLANK.
    I HAVE FOUND A COUPLE SITES THAT REFERANCE THIS SAME PROBLEM, IT APPEARS TO BE AN ISSUE WITH THIS MODEL. HP IS NOT RECONISING IT AS A DEFECT. I WILL ATTEMP TO REPLACE THE POWER CORD, THIS HAS SOLVED SOME PEOPLES PROBLEMS.
  • Anonymous Apr 17, 2008
    everytime i turn the screem on everything is find, but after 1-2 second everything turn to black, but the power button is still blue. Do you know the problem to this?
  • 472 Answers
You are not looking for a problem in the inductors. There are 4 transistors (2 pairs) near the transformers where the CCFL's plug into the board. They short out and you end up with your problems.
The transistors have 3 legs and stick up out of the board. They will look fine visually, since they are shorted internally.
Hope that helps =)
Posted on Apr 09, 2008
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
JVC LT-24HD32J TV SCREEN GOES BLANK AFTER 10 SECONDS WITH JUST THE SELECTED CHANNEL DISPLAYED.
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | JVC LT-32E488 32 in. LCD Television
Monitor keeps going blank - when im on internet it will suddenly go extra bright for a half second, the blank. if I switch it off using the button on the side and switch it on again, it just goes blank...
loricaney, Do some research first. Go here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ I just read a comment that some guy wrote. He stated that he aquired 30 Vs17 non-working units from a high school, and that 25 of them had bad (swollen or leaky) filter capacitors. The other 5 had cracked lcd panels. maybe $6 in new capacitors will restore unit for you. Do some reading in my fixya profile and "budmrtn" and "buddymc" fixya profiles. let me know if you want to do a DIY repair after you do research and visit YOUTUBE for video clips of owners doing typical capacitor removal and installation. 12fixlouie
Aug 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My hp pavilion F1703 monitor goes blank about every 30 seconds.
Thsi model has known problem with bad solder joints due to contamination, you need to remove the old solder on the four inductor leads, clean the leads eal well and resolder, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Al so look to see any one of the capacitors have bulging top, they should be completely flat top.
Jun 06, 2010 | CTX S762A 17" LCD Monitor
My hp f1703 monitor just turns off on it's own.
Common failure in this monitor is the poor soldering works on the doughnut (4) shape inductors in the inverter board, http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Feb 18, 2010 | HP Pavilion F1703 17" LCD Monitor
Dell E153FPd Power stays on but video goes off after 2 seconds.
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
LCD monitor image blinking
There are two coils in the circuit board that normally causes this problem due to dry solder. try to desoder clean and resolder these coils.
Hope this helps.
If it does, please vote. Thanks!
Apr 28, 2008 | Gateway FPD2275W LCD Monitor
F1703 monitor goes blank after 1-2 seconds
Resolder the Red Invertor transformer and power transistors around it.
Samir
Mar 11, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion F1703 17" LCD Monitor
Sounds like cold soider joints on your video board. If you take apart the lcd screen and get to the video board, theres 4 capasitors with cooper coils around it. you can add soider to it. theres 2 pins for each. I fixed 15 or more for that same model. Its a known problem with that model. Hope it wworks for ya
May 05, 2006 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
