Drum noise I have a Kleenmaid KFL1500 washing machine which is just over 5 years old. So far it has been working ok until recently it developed a noise while going through the spinning cycle. It sounds like the drum is knocking on the inside walls of the machine. Does anyone know what the problem is?
  • geralyn2 Apr 08, 2008
    I've just recently discovered the same problem. During the rinse cycle the drum start beating against the walls of the machine. Please inform me of a solution
  • 129 Answers
Good day.
Maybe there are coins left in the pockets that stucked within the drum during drain process. You can also check the bearing holder of your washing machine for this is also one of the reasons why noises occur during oepration
chris
Posted on Mar 11, 2008
SOURCE:
My bizhub 350 still says please wait even the fuser unit & lamp is ok. how do i reflash firmware?
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 02, 2017 | Minolta bizhub 350 Black and White Copier
Kleenmaid dryer
Either needs the drum bearing greasing or needs new bearings
Jun 28, 2014 | Washing Machines
Please wati mesage on power on on bizhub 164 machine
Sir/Mam Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jan 16, 2014 | Konica Minolta bizhub 200 Printer
Bosch washing machine model WFF1401GB/01, 10 years old, motor was replaced 5 years ago (so motor is 5 years old now). Drum has stopped rotating, pump etc all OK. Carbon brushes replaced, drum did work for...
Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Bosch Washing Machines
My Top Loader US Whirlpool LSQ washing machine (5 years old) has developed a problem. The machine fills ok, but does not wash and at the end of the wash cycle the machine empties ok. During the washing...
Sounds like you have a failed motor coupling. This is an easy fix, requires inexpensive parts, but is going to take a little effort and know-how on your part. If you click on the following link, it explains step-by-step how to replace the coupling:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is 285753A and can be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Brake/Clutch/Gearcase/Motor/Pump" heading. If you require further assistance, please let me know. I hope this helps you resolve your washer problem.
Jun 30, 2008 | Washing Machines
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Noisy
usually a noisy machine means either the main bearings have gone or the motor has got damaged/worn in some way. to check the main bearings try lifting the drum with the hand from inside or rotate the drum with the hand to see if the rumble can be felt. i cannot think what else would cause a loud humming though.
Jun 11, 2007 | Zanussi FJ1454W Front Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
How much play in rear pulley
Scott, the pulley should be tight, no play, Check to see if one of spokes are cracked on the pulley. I do believe that you have a 5 year warranty on the bearings on this machine, parts only. It's a huge job to replace the bearings on this model. Give Sears a call to see if they will cover the parts. You will need the rear tub and bearing kit...Good luck
Jun 21, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
275 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
