Question about Lexmark JetPrinter Z605 Color InkJet Printer
Printer z605 won't print. nor will z35, both lexmaker, I have the disk for z35.
I have downloaded driver and divergenius 2007 but printer still will not print If I go do diagnostics it says it is installed properly. What is wrong?
  • mangojam5 Aug 13, 2008
    my son's z605 runs the page through, but nothing is printed on it.I installed drivers and hooked it up to my system and the same problem occurs. Can you help?
    Genius:
  • 3,587 Answers
Does it do a test print from the panel?
Posted on Mar 11, 2008
I cannot print after install the driver
After installing the printer driver did you do a test print?
If it did not do a test print then either the wrong printer driver was installed or the printer cable is not connected properly or the ink cartridges was not installed properly. New ink cartridges need to have the air hole protection stickers removed.
Mar 12, 2013 | Office Equipment & Supplies
Hp P3005n. I have a problem with tray 1. the feeder flaps when i send anything to print and this causes a jam. what can be the cause. it never use to flap before. Now for some strange reason it does....
Hi there
Can you try to add new printer and set it as default printer. Because I believe the old printer driver got corrupted. If it prints the test page, then it solves your problem. Normally a driver can be corrupted that receives wrong command from the computer.
If still not working, try to click and download this PRINT DIAGNOSTICS UTILITY (blue text). Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/ .It is use to fix errors automatically in your printer. Download, unzip and install it to your computer. I will helps you solve your problem.
Regards
Feb 10, 2011 | HP Office Equipment & Supplies
Printing labels from SAP ECC 6.0 using smarforms, label prints however the printer commands themselves are showing on the label, not just the information the print commands are to control. Is there...
Hi there
Does this printer connected with your computer? If yes, there is a problem on printer driver. You need to add new printer with same name and if this successfully installed, you can delete the old printer icon.
When there is errors message or wrong command of printing, the usual problem is corrupted driver.
Another way to correct this is to uninstall and reinstall the printer driver if the first solution does not work.
If still not working, try this download and install the print diagnostics software. It will helps you to find and fix errors in the windows registry. Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Click on the blue text PRINT DIAGNOSTIC UTILITY and it will download automatically. Unzip it to install to your computer.
I hope these solutions solve your problem. Regards.
Feb 09, 2011 | Zebra RW 420 Thermal Printer
Operation cannot be completed. print spooler service is not running
Download the HP Diagnostic tool to correct the problem.
  1. Download the "HP print diagnostic utility" click here to download.
  2. After downloading the tool, (print diagnostic utility) save it to your computer.
  3. Run the tool, then select the printer that your using, then start scanning the problems on the printer.
  4. It will tells you if theirs a problem with the connectivity, ports, print jobs stuck in queue, services and etc.,
  5. If the problem appears, theirs should be a "Fix" button available or "uninstall the driver".
  6. If theirs a fix button, click on it to fix the issue, now if its telling you to uninstall the driver. Please do it.
  7. Restart the computer.
  8. Re install the driver of your printer.
It should be working fine now, but if you are still having issues with it. contact HP's printers department 1-800-474-6836.
Feb 04, 2011 | Office Equipment & Supplies
Everything is hooked up properly, The printer is found on my computer, but the printer will not print
If you do not already have the HP Print Diagnostic Utility installed go here. Select your operating system, a menu of available downloads will open including the Print and Scan Diagnostic Utilities. Recommend you update your driver if necessary and download the utilities for your printer and operating system.
If you do not know your operating system, open Control Panel, click on System, look under System Type.
For guidance see here.
Jan 16, 2011 | HP DeskJet F380 All-In-One Printer
Installing HP4795 printers in Windows XP. During install XP cannot find print drivers. Can you tell me how to point install to the print drivers?
Click on the link below to download the Printer Drivers and later install them.
Download Link
After you download the file, run the file to start installation and complete the installation.
Disconnect the Printer cable before the installation starts and connect it when asked to.
If for any reasons, it does not recognize the printer connected, complete the installation by clicking on the option ( I will connect the printer later ) and complete the installation.
Then Click on the Diagnostic download option below to run the diagnostic tool to diagnose the issue.
HP Print Diagnostic Tool
My Suggestion would be to completely uninstall the software and reinstall it using the Download Drivers option above in this solution.
Thank you for contacting FixYa
Regards,
Ron
Dec 23, 2010 | HP C4795 AllInOne InkJet Printer
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Will not print
Does this happen when you print from a word document, PDF etc..
What operating system are you using?
if you are using Windows
open your printer folder from the control panel print a test page from the driver.
If you try to print something and strange characters print.
either you have a corrupted print job in the memory..
Clear the Print que from the PC, unplg the printer for a few minutes.
You possibly could have the wrong drivers installed, which will also cause this problem.
this is a link to Lexmark, and you can down load the proper driver here.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:436:0:0
Aug 19, 2008 | Lexmark X2250 All-In-One InkJet Printer
Not Printing
is there a possibility that the office 2007 downlooad was corrupt ?
This version of office, is noticably sower than previous versions, of Office.
I personally prefered Office 97, 2000 was the same, glitchy and very sluggish. it,s ok upgrading to these latest versions, providing you have the Computer specs, to match the software requirements. Hers a couple of Options.
1:- un-install the Office 2007 program, hopefully you have a version on cd of your older version ?
2:- if your running win XP, restore your computer to an earlier restore-point, before the upgrade.
This will reset your computer to how it was before the download.
3:- un-install then re-install your printer and related software/Drivers.
Mike @ compurepair.
Feb 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
Lexmark JetPrinter Z605 Color InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
