About 52 in zenith tv fan
Does the fan in back of tv suppose to stay on all the time
  • 8,617 Answers
If the air filter needs cleaning The fan will stay on for an extended time to cool the light engine. Try cleaning the air filter that should solve your problem
Posted on Mar 11, 2008
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
Zenith 52" LCD. When the lamp goes out does the sound go out also? Tv wont turn on and the power and lamp light flash red. no sound.
Has Lamp been replaced? Also if Blaster board is bad Lamp will not turn on also CK Fan behind Lamp If it is not running Set will not turn on For Parts Try Encompass 1-800-639-3328 or look on line www.Encompass Parts, Also Look on E-Bay for Lamp and Blaster Board I found Lamp fot mine for 85.00 and blaster board for 55.00Type in Model number it will be on back of your TV.
Nov 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
How do you replace cooling fan in M52W56LCD? where to purchase?
Obviously, check the fan to make sure it is running. Second, see if there is anything obstructing the fan, and then make sure all filters and fans are clean and free of dust build up.
Jan 07, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith power will not stay on
Either replace Lamp or Fan is bad.If lamp has been replaced its the FAN, fan must run at all times in order for set to come on and lamp to stay on.
Dec 12, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith projection tv
Bad Light engine cost was 1900.00 sure it is cheaper now.call UED 1-800-648-6657 for replacement cost.
Oct 12, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith D52WLCD 52 in.
if lamp replacement doesnt fix the problem then you are looking at a light engine
Aug 29, 2006 | Zenith D52WLCD 52" Rear Projection...
Concierge series 25" wont stay on channel 3
If Im not mistaking , some of Zeniths TV sets cannot be unplugged or disconnected from the wall. It will delete the memory and I guess the default channel is Channel 52.. I didnt know you disconnect the set in the ? you asked before. To stop this simply plug the set into an always on wall receptical and turn on the cable then the TV set. your going to need to do this order of operations as I know Zeniths will detune and you wont get any color sometimes if you turn on the TV then the cable. Sorry nothing you can do short of getting another set. Good Luck
Jul 30, 2006 | Zenith C27A24T 27" TV
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
