Back to:
Tags:
Kitchen Cooktops
Generic problem for all Kitchen Cooktops
Romvoing the top of my Whirlpool Cooktop
posted by eddiemoth on Mar 11, 2008
Hello folks,
I have one of these whirlpool cooktops installed by the builder so I can't find the model number. The problem now the igniters are not working for all for five burners. By reading some of the resolutions here, I think the igniter unit is not working so I want to try to replace the igniter unit. However, I can't figure out how to remove the top. Does anybody have any idea?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 12, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
aborcass, thank you very much for checking this for me. When turning on one or any burner, there is no clicking except I can smell gas. So I called Mr. Appliances in my area to come in and diagnose it. Without even remove the cooktop, he said he is very sure that it is the spark module and he wrote me an estimate of $470.
I thought that was too expensive so I paid him $74 for the estimate. I checked Partselect, they sell the spark module for $97 so I would like to try to fix this myself if I know how to remove the top. So do you think that prying the fiber glass up and remove them is the way to do?
I saw another post here on Fixya and the resolution was done via a burner. That does not sound like it is working for my case. Any advice or hints on how to remove the top is very appreciated.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Romvoing the top of my Whirlpool Cooktop:
I don't want to Accept this solution
Solution #2
Not Rated (0)
aborcass
Rank:Guru Guru
Rating: 90%, 1441 votes
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
Thank You!
Can you Help with these Kitchen Cooktops problems?
Kitchen Cooktops
and at the same time a flashing ''F113'' in the window...
Jenn-Air JED8430 Electric Cooktop
Have a c202 Jenn-Air cooktop. Wiring from power supply...
Kitchen Cooktops
Is it difficult to repair and what are the steps?
Jenn-Air 36 in. CCG2523 Gas Cooktop
None of the ignitors are working. I check the power source...
Kitchen Cooktops
hi i am in need of a belling 120r oven wiring diagram, if...
Loading problems.
Repair Service
Find Kitchen Cooktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
