Question about Dryers
WASHING MACHINE WHIRLPOOL
SO IT IS POSSIBLE I MOVED IT OUT OF PLACE AND WITH EVERYTHING WORKING THAT IS POSITIVE RIGHT I HAVE A FRIEND COMING OVER TOMORROW TO HELP DO WHAT YOU SUGGESTED TAKING IT APART AND PUTTING IT BACK IN T RIGHT PLACE I HAVE NOT HOOKED UP THE WHIRLPOOL DRYER YET THAT WAS ALSO TRANSPORTED ON ITS SIDE IS THERE GOING TO BE APROBLEM WITH THAT TO THANKS
    Problem Solver:
  • 6 Answers
I wouldn't think you will have a problem with the dryer. They have more supports for the drum. But anything is possible..lol. After you get the washer set up, Plug the dryer in and try it first before you move it into its final place. If you don't have an appliance dolly it is a good idea to rent one.. Much easier to move these things around and saves your back.
Posted on Mar 11, 2008
Whirlpool Duet Washer dispenser arm always starts cycle in fabric softener tray and bypasses soap tray.
Are you getting an error code possible F28 its possible its something in the linkage take the top off and start any wash cycle the dispense motor should move the diverter to the wash cubicle look or listen for any popping noise as if linkage is binding if nothing found I would suspect the motor it has contacts inside that feed back to the control indicating its position if the internal gears are slipping then the motor will rotate till contacts made regardless of diverter position
Apr 03, 2015 | Whirlpool Washing Machines
Whirlpool washing machine is no good
I can't tell you the countless amount of those I've had to repair and all within the first year while doing warranty work for whirlpool. My fix for it was to make sure the belt was on the pulley, push the pulley up into position, and put a small amount of lock-tight on the bolt the place the nutt on and ratchet it on as tightly as possible. Never had a recall with that method.
Apr 29, 2012 | Whirlpool CAM2752KQ Top Load Washer
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Our Whirlpool AWZ412 washer/dryer just stopped during the wash cycle. It did seemed to have moved 5 cm out of place, possibly due to a disbalance during the cycle. We tested the outlet, swiched the machine...
This could be the door latch switch that has failed or came loose, it may also be that the off balance load caused such a bad vibration that the wires have come loose or broken to the motor.
Dec 15, 2017 | Whirlpool AWZ412 Front Load Washer
I have a whirlpool wfs 1071aw and havent used washing liquid before only powder...cant find my manual and when I put the liquid where I would have put powder it leaks soap out of the dispenser onto the...
You should have a little divider in the soap drawer , it needs to be moved into a different position for liquid ( holds the liquid until the cycle begins)
Mar 15, 2011 | Washing Machines
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Oct 12, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Dryers Logo
Top Dryers Experts
