Back to:
Tags:
Electric Fans
Generic problem for all Electric Fans
Minka aire ceiling fan
posted by ToyWhite on Mar 11, 2008
I had a minka aire ceiling fan installed about two years ago. Tonight the 50 watt halogen recessed light bulb burned out. We went to replace it, but as soon as we put it in, and then turned it on - it blew the bulb out?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 31, 2008
Not Rated (0)
terrelm72
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Minka aire ceiling fan:
I don't want to Accept this solution
Can you Help with these Electric Fans problems?
Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
the problem began with the light blinking and then it no...
Hunter 52" Ceiling Fan With Light And...
I have replaced the battery in remote but didn't help....
Quorum Ceiling Fan - 138880
I have two quorum ceiling fans and the switch that changes...
Electric Fans
I have several lamp sets that need rewiring. They are...
Was given a 52" Hampton Bay ceiling fan, but did not...
Loading problems.
Repair Service
Find Electric Fan Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
