Question about SanDisk Sansa View 8GB MP3 Player - Black
Sansa view it wont let me sync music to my player and i just bought it today and dont want to have to return it
  • Nikki m Apr 01, 2008
    just bought sansa view won't connect to my computer
    my windows media player does not see that it is connected via usb
    I have rebooted, turned mp3 on and off
    sometimes when I disconnect it will stay connected but computer does not see it
    nikki
Try all your USB ports - I found that some are USB 1 and some are USB 2 and the view only sync's when plugged into a USB 2 port. I was worried too until I found a lone USB 2 on my dell and plugged into it and tada - it worked!
Posted on Apr 06, 2008
    Problem Solver:
You can just slide the button th hold then press the center button. it should work
Posted on Mar 16, 2008
SOURCE:
My sansa fuze wont let me listen to music
Open media player to view all your files.
Connect sansa and make sure computer reads it.
Now on top of media player, you will see a sync button, press it now.
Now copy songs from your list and add them to the box on far right screen. Then sync to device.
May 13, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa view
I had the same problem and finally solved it by downloading latest firmware and then re-formating. You lose all the uploaded songs,etc. that were on the player, but the battery holds charges just fine after this. Since all the music I wanted was already in windows media player, it took one quick sync to get it all back on the player.
Sep 28, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Lost music
you can go to (if you have windows media player) sync button, click the little arrow and click the button that says Sansa Player (or Sansa View) then you can unclick the autosync device.
Jul 25, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sandisk Sansa e260 gone retarded 4.0GB
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 28, 2008 | SanDisk Sansa e260 MP3 Player
Loading music
What are you using to load music. If you have access to Windows Media Player 11 it is very simple.
First open WMP11, make sure your player is connected to the computer with the USB cable. At the top of WMP11 click Sync
the player will sync with WMP11, drag and drop music and click sync, very simple. I have a Sansa View and it is very simple, This basically works with most MP3 players.
Feb 25, 2008 | SanDisk Sansa e200 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
56 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
