Toshiba CF36G40 36" TV
Problem for Toshiba CF36G40 36" TV
The dropped television
By maggie2008 on Mar 11, 2008
The screen isn't cracked it is the black plastic around the television how do you know if the tube is broke would it have a white line when you turn it on?
I was really just wondering if it was worth taking it in to the shop??
Comments:
Mar 11, 2008
- Thank you for all your help.
Best Solution
posted on Mar 11, 2008
Very Helpful)
BFixed
Rank: Guru
Rating: 86%, 97 votes
If it has a white line across the middle then it is probably repairable.
If the screen was cracked it could, but probably wouldn't work at all, not even a white line. The white line indicates that the vertical deflection IC has failed. Generally these IC are inexpensive and should only take an hour, if that, to replace. A good technitian should be able to repair it at a reasonable cost as well as check it over for other common problem areas.
Was this helpful?
Yes
No
Popular Solutions for Toshiba CF36G40 36" TV
Questions and Unsolved Problems for Toshiba CF36G40 36" TV
Do you recommend Toshiba CF36G40 36" TV?
Answer
Answer
when i turn the TV on all I get is a grey screen with white lines.
Answer
trying to remove a horizontal line from the left of the tv.plz help.
Answer
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to... (More)
Answer
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable... (More)
Answer
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba CF36G40 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
