Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
Anonymous Posted on Mar 11, 2008
Web access I need to find out how to access the web from my phone. As of right now i deleted all my network and motosync partner setup details i need those details in order to get on so if anyone has the exact setup i need please contact me.......
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 17, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
8390
Points
26
Contact ur gsm operator for web settings
2helpful
When I try to access my cisco e1000 router on firefox or google it keeps saying that it is busy and will not connect
Are you trying to access the setup page of the router?
Did you install the Cisco connect software on your main computer?
If you have cisco connect software installed then open Cisco connect.
Go to Router settings. Click on Advanced settings. It will open the setup page of your router.
If the cisco connect is not installed then try to power cycle the router. Unplug the power to the router, wait for 30 seconds. Plug in the power cable. Wait for 30 seconds.
Now try to access the setup page.
If that is also not working then I will suggest you to reset the router and reconfigure it manually.
Watch video.
How to reset Linksys router.
Watch Video:
Linksys router setup
9helpful
3answers
Cnnot send or receive mms on samsung gt-i9000
Hi there this problem is very easy to solve have fixed both my sons and partners phone today..Ok this is how you do it..
Step 1.Go to settings then wireless and network then mobile network settings..
Step 2.Make sure Use packet data has a green tick..Then go into Access point names..
Step 3.Now you want to select Internet which is the first one then hit left hand menu button so you can delete APN once you delete it go to mms second on the list and delete it the same wait if you have more access point names in here delete them too..
Step 4.Now hit the back button once theres no more names in the list to where it says Access Point Names then go back in again and hit left hand menu button and you want to touch on Reset To Default...It will reset the settings for you and thats it DONE you will be able to send and receive mms and surf the internet hope this helps need anymore more help email me on [email protected] :)
4helpful
2answers
I can't send MMS from my galaxy s GT-I9000 , Please help !
Hi there this problem is very easy to solve have fixed both my sons and partners phone today..Ok this is how you do it.. Step 1.Go to settings then wireless and network then mobile network settings.. Step 2.Make sure Use packet data has a green tick..Then go into Access point names.. Step 3.Now you want to select Internet which is the first one then hit left hand menu button so you can delete APN once you delete it go to mms second on the list and delete it the same wait if you have more access point names in here delete them too.. Step 4.Now hit the back button once theres no more names in the list to where it says Access Point Names then go back in again and hit left hand menu button and you want to touch on Reset To Default...It will reset the settings for you and thats it DONE you will be able to send and receive mms and surf the internet hope this helps need anymore more help email me on [email protected] :)
How to get my wep
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
1helpful
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
2answers
I forgot my pass phrase...what now?
1. Open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
For Windows Vista:
I HAVE A LUCENT partner 18D PHONE AT MY OFFICE.
What voicemail do you have currently?? When you dial into voicemail, what does the voicemail lady say? "Welcome to Partner......."??????? Need to know that first.
Not about razr about a rizr z3
you should contact your mobile service provider and have them setup your internet on your phone.
Little problem with my web access
Well, what is your carrier?
Mar 11, 2008 • Cell Phones
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
