Whirlpool washer noise
PURCHASED A USED WHIRLPOOL TOP LOADER MODEL NUMBER LSC9355E0 TRANSPORTED IT HOME ON ITS SIDE FOR ONE HOUR IN A SUV. WAS TOLD BY AN APPLIANCE STORE I COULD DO THIS. SAW MACHINE WORK AT ORIGINAL OWNERS HOUSE NO NOISE PERFECT. ONCE HOME AFTER BEING ON ITS SIDE AND BEING PLUGGED IN HOSES ATTATCHED THE NOISE WHILE IN SPIN AND BEFORE IS VERY LOUD LIKE THE INSIDES ARE COMING OUT. THE MACHINE SPINS GREAT, WORKS BUT COULD I HAVE LOOSENED SOMETHING WHILE TRANSPORTING IT ON ITS SIDE. WHEN I LOOK UNDER MACHINE WHILE SPINNING I SEE METAL MOVING LIKE ITS NOT TIGHTLY ATTACHED IS THAT FROM ME MOVING IT DID I BRAKE IT BY MOVING MACHINE ON ITS SIDE THANKS COULD IT BE NOT LEVEL HELP !!!!
    President:
  • Washing Mach... Master
  • 2,651 Answers
Moving it on side might empty gearcase oil, any yellowish oil drippin gout of anywhere? hard to tell about hte metal movig around, its quite normal for machines to move around quite a bit on the inside
Posted on Mar 11, 2008
I have an e3 and e2 on my whirlpool top loader washer
Hello Jenny ramos! We are terribly sorry to hear of your concern with your Whirlpool Washer. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer id (Jenny ramos), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 17, 2017 | Whirlpool Washing Machines
Tip
Purchased my Whirlpool front loader 4/2004, we are on our 7th bellow, new inner...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
How do I install the control board part # W10180782 in a whirlpool washer
Since you did not mention the model number to your washer or whether it is a top or side load washer, I have attached a youtube video for you to watch to get the general idea of how to gain access to the control board on top-loader whirlpool washers; although it is not specific to the part number you are replacing. Repair clinic offers self-help videos on side load washers as well in case yours is a side loader.I hope this helps.
Feb 20, 2015 | Whirlpool Washing Machines
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
Feb 03, 2011 | Washing Machines
Model and serial number
If this is a Whirlpool manufactured TOP LOADER (such as the one you posted this question under), the model number and serial number are located on a nameplate along the wash tub rim under the lid.
If this is a FRONT LOADER, the model number and serial number will be located along the door facing as you open the door.
If you have questions, please post back and let me know. I hope this helps you.
May 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a maytag top loader washer and when it is on the spin cycle the whole drum shakes hitting the walls of the washer
Without having the model number, it is difficult to diagnose.
Most Maytag / Whirlpool top loaders use a set of balance springs and friction pads to buffer the shaking.
Here is a Whirlpool site with a number of PDF files on their products including troubleshooting sections.
Find your washer under laundry products and open the PDF, it will probably take a few minutes to load.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
Sep 27, 2009 | Washing Machines
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
im going to assume its a front loader. try opening the access panel by removing 3 screws along bottom front of unit. give a look inside, there should be 4 suspension/shock absorbers holding drum form shifting.If disconnected the just "snap"into place with quarter turn into holder.while under there the pump is located right there in front, open the "button trap" front of pump see if perhaps theres something inside pump housing making noise
Mar 11, 2008 | Washing Machines
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
