Question about Casio EXILIM Card EX-S770 Digital Camera
Problem saving setups EX-S770 BE
Each time i turn on my camer it requires me to set-up the countyr, time and date information. I no longer seems to be keeping that info in flash memory. I uploaded new FW and have a fully charged battery. Any ideas?
  • 1 more comment
  • Amichai Mar 20, 2008
    My Casio Exilim camera asks me to set up country, date and time every time i turned it on!!!
    The manual said i should charge it for 24 hours which i did but still, problem is not solved.
  • Anonymous May 05, 2008
    I've tried resetting my camera but have the same problem each time I turn it on. Language, country, date and time are all lost each time I turn the camera off. Battery is fully charged.
  • Anonymous Mar 28, 2014
    my ex-zs5 flash doesn't work. and i keep on turning the flash on but its not working and i cant set it up,it keeps on going on flash off when i turned it to flash on, what to do help
Tried it twice, doesn't seem to solve the problem...
Any one else who can help me with this?
Posted on Apr 24, 2008
  • 374 Answers
Try resetting camera, take card out and format internal mem. Reinput your information and then turn off. If you have to re-enter again then it's a repair issue. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
My Casio ES-S770 will not hold the language, time and date settings when I shut it off
This means that either: 1) You took the battery out also and that reset the settings
2) The internal battery in the camera that saves settings ran out of power somehow
3. The batteries you used died
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Started defaulting to setup mode every time it is turned on
It sounds like the internal battery which keeps the time and date running is empty and has to be replaced. You should contact your local Casio service center or other local camera service center, maybe they can get the battery from other broken camera.
Hope this helps!
Jul 29, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim works on cradle, wont turn on when off cradle
I would guess that the battery is not being charged. The problem could be poor connections between the charger & Camera or between camera and battery; or the battery no longer will take a charge.
First, clean the connections with the eraser end of a pencil. Clean the connections on the Charger and on the camer; clean the battery connections and in the camera, Charge overnight. If this does not get the camera working, borrow a battery and see if this works.
Jun 22, 2009 | Casio EXILIM Card EX-S770 Digital Camera
How do I set the time on my Pioneer RT500?
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
1 Press SETUP while the DVD and video tape is
The SETUP MENU screen will appear.
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
3 Press  or  to set the value of the selected
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Casio Exilim EX-S770
Can you see pictures already saved on the camera? If not, the card may be corrupted. Try to format your card if you DO NOT have important pictures on it.
Aug 20, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Starts at menu
with the Casio Z45 they seemed to have a similar problem and suggested that you format the internal flash memory.
Remove Card
Turn on camera
Set Date etc
Format Memory and turn off.
It didnt work for me, but you may have more success!
Sep 05, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Jun 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
135 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
