Back to:
Tags:
Winsource Tech Solutions TS-4500 Cross-Cut Shredder. Price Shown Reflects Instant Savings.
Tech Solutions shredder
posted by granddad60 on Mar 11, 2008
When I put paper into the shredder, it doesn't automatically shred the paper. I have to reverse the shredder and then turn it back on when paper is loaded. I need to do this each time i want to shred a sheet of paper
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 21, 2008
Not Rated (0)
fellowesrep
Rank:Guru Guru
Rating: 87%, 115 votes
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Tech Solutions shredder:
I don't want to Accept this solution
Can you Help with these Shredders problems?
Shredders
need help can't aford to buy another one
Winsource Tech Solutions TS-4500 Cross-Cut...
I am getting trouble with deep freeze software which...
My paper shredder is On?Auto and the green ready light is...
The plastic flap that hangs beside the blades inside the...
My shredder will reverse paper but not longer shred in the...
Loading problems.
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
