Question about Pioneer DEH-P3500 CD Player
Wiring diagram i bought a 3500 and it has the splitter plugs there and before i hook it up i would like the wiring diagram to make sure i have it right. this plug from radio splits into 2 plugs off of it. one plug has 6 wires and so does the other and then the ground wire
  • brif Mar 11, 2008
    need help i would like a wiring diagram for a 3500
    Sergeant:
  • 300 Answers
Here's a link to the Installation Manual.
Here's a link to the Owner's Manual.
Posted on Mar 11, 2008
How to find audio fix on my LG flat screen tv to finish connecting my wireless head phones
Well Hi Maria ! Let's get you fixed up.
I want to help you with your question, but I need more information. Maria, with my wireless headphones, I have 2 types:
a)Has 2 "RCA Type" connector plugs, you can identify them simply as one is red(My memory trick is R is 'RED & R for right side, and a white one, for the left side) do you see these plug type connectors that attach to the broadcasting unit that sends the signals to your wireless headphones, so they can go without wires?
b) Or...do you have a broadcasting unit that has 2 different types of plugs, 1 is still a red "RCA type", and the other is a different type, a "BLACK" Plug type ?(It is called a 3.5mm Plug)
If you have "type a)" 1 x Red RCA &
1 x White RCA, then all you need to do is to look at your HDTV manual, an find where the "AV OUT" plugs are, make sure it is the OUT, (Caution: It won't work if there is "NO" audio from some source hooked up to at least one the HDTV's in sources, it could be AV, or HDMI, whatever you chose to use.
Carefully move the HDTV, so you can safely get behind it and locate the AV OUT (Female type) plugs at the back, remember "R" is for RED PLUG & always "RIGHT" Side, and "WHITE" PLUG is for the "LEFT" Side. Hopefully the cords are long enough to get out from behind the HDTV, andto a place where their signal can reach the headphones. If not, I get very inexpensive RCA cables, & other things at "My local DOLLAR STORE, for about $3.00" And you should be set. Remember, Start your headphones with reset, and slowly search until your audio matched the video on the HDTV.
If you have the "type b)" you have 2 options. If you plug just the "RED RCA plug into the back of the HDTV, IMPORTANT** You will ONLY get (Remember "R" red for Right hand side) you only get Right Had Sound (REALLY, who wants that, with all the nice stuff you bought ??)
Soooo... That "BLACK 3.5mm Plug means you have "2" choices
a) Unlikely Choice- If there is a 3.5mm audio OUT Female Plug receiver that accepts the Black plug, then THAT's IT. The Black plug. is like most microphones, headphones, etc, IT HAS BOTH THE LEFT & THE RIGHT SIDE SOUND SIGNALS> Again, if it's not long enough, , go buy an inexpensive extension plug (Factory Direct Store sells a 25 foot extension cable ***FOR ONLY $6.99 ****-
- I love that place !! )
b) if like most HDTVs you have the same 2 RCA type AV out Female Plugs, you will need to buy what is called a
"3.5mm (Female)to RED & White RCA PLUG SPLITTER" -
and guess where you get them reaaly cheap ??
See above !!.
When you have your RCA to 3.5mm Splitter Cable (Hey it's late & I don't remember the right name, I think this is the one !!), plug The "R" for RED to the "Right" side AV RCA plug for AV OUT, & the "White" plug" to the "Left Side" AV out plug,& the 3.5mm Black Plug (female) will plug into the Cordless Headphones Broadcaster's (Male) 3.5mm Black Plug, move the Broadcaster out front so your Headphones can pick up the signal
LAST !!!
2 things
#1- Always try to be sure that you could draw an imaginary "LINE OF SIGHT" between the Broadcaster Unit, and where you will be wearing the headphones for the best quality of signal (You want to enjoy it now, right !)
#2- BE VERY VERY CAREFU, PATIENT, when you move the HDTV back or foorward. They are EXPENSIVE !! AND !!! IMPORTANT, !! They are a LOT HEAVIER THAN THEY LOOK< AND COULD REALLY HURT YOU,if they fall on you, or you will not feel so smart if after all this, your nice, expensive HDTV, is BROKEN, OK?
PLEASE BE CAREFUL FOLKS !!!
Apr 29, 2016 | LG Televison & Video
Replaced heater core stop turn and hazard lights all stopped working!! ??? what should i look at fuses all good!
You hooked something up wrong or not at all ,it shouldn't have blown a fuse ,did you disconnect the battery before doing the heater core . Find wiring diagrams an check power an grounds to those circuits . Go to YouTube an check out some basic electrical trouble shooting videos , an voltage drop testing videos.Basic Electrical fundamentals an so on. They worked before right ?
Dec 02, 2015 | 2001 Dodge Ram 3500 Truck
I just bought a horse trailer and when I hook it up to my 2006 Silverado, the lights don't work. My trailer hitch and wiring system are new, and the previous trailer owner tested the lighting of
Some people wire trailer plugs differently. If the plug is not wired differently than yours, make sure the tow ball is clean. No rust. That's where the trailer gets its ground from. Usually they will work if thats the case, but not right. I can't remember what the wire colors are right now. Go to etrailer and look up the diagram.
Feb 05, 2013 | 2006 Chevrolet Silverado
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I have put a hitch on my 2001 Ram 3500 now I would like to hook up my electric for a flat 4 way plug
They sell a pre-made T that you just unplug your existing wiring and plug in the T. The T has the flat plug on the end of it. Very easy, and don't have to worry about splicing. It just plugs right in.
Sep 22, 2010 | 2001 Dodge Ram 3500 Truck
Spark plug wiring diagram
If u can't see the diagram go to the link, just match up the numbers on the coil to the engine cylinder numbers.
http://autorepair.about.com/library/firing_orders/bl-fo-5630.htm
Apr 05, 2010 | 1997 Pontiac Trans Sport
I need a wiring diagram for a 1999 3500 chevy van. Because of geing no power to the fuel pump
hi i havw a 3500g 1998 vortec we have no constant spark we need to find a wiring diagram whats the best sie to use not sure if some thing is wrong with the plug to the coil?
Oct 19, 2009 | 1999 Chevrolet 3500
I dont know how to wire it to my car stereo wires
Do yourself a favor and run to audio store or even autoparts store & get an adapter plug/harness, cost is a few bucks but well worth it. It plugs into factory harness & you wire your new stereo to it according to diagram with new system.
May 02, 2009 | 2001 Dodge Stratus
I HAVE PINK AND GREEN AUDIO CABLES BUT ONLY ONE SPEAKER PORT ON M
Hello bluangel88,
Thank you for choosing fixya.com. Go to your local computer accessories dept. store (Wal-Mart, Fred-Meyer, or other Electronics store that sells computers and accessories) - Ask a representative about a splitter that will allow you to plug the two speaker wires into the splitter, which will then plug into the one speaker port on your computer.(may need to take wires, if detachable) or speakers with you. This will make it easier to locate the correct adapter (splitter) for your speakers.
I hope this information is useful,and I hope you find what you need to get your speakers working.
Thank you again for choosing fixya.com,
carsandcomps
Guru, fixya.com
Oregon
Apr 04, 2009 | Logitech OEM S220 2.1 Speaker Black...
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Pioneer DEH-P3500 CD Player Logo
337 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
