HR 798 Headrest DVD Players. Neither will read a disc. Had the units in for 2 months and now in one week they both stopped working. Never changed any "region" stuff. Tried with brand new DVD's as well. Bought a dry lens cleaning kit...will not recognize that disc either! Help!!
  • rugbyduck Mar 11, 2008
    No. Are you saying they are known for that?
    Brigadier General:
  • 3,614 Answers
Are you familiar of the optical problem?
your unit is probably got it, why it cant read disc..
thanks,
Posted on Mar 11, 2008
  • micromaster
    micromaster Mar 11, 2008
    yes..
    the optical lens is the one read the surface of the disc..
6ya staff
SOURCE:
My Panasonic DMP-BD655 won't read any discs. I was fine a month ago but hen it wouldn't read Blu-Ray discs, but would still play DVD's. It stopped playing DVD's about 3 days ago. I have upgraded the...
Ive only had mine for 2 months and it just stopped playing dvds all together. I had a brand new dvd playing, went to switch it to another new dvd movie and it wouldnt read it or any other dvd Ive tried. I havent tried a blu ray disc yet.
Jan 02, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Will not read disc
As it's less than a year old the manufacturer's warranty should still apply.
Your player probably has a failed laser head unit; if you have to pay to fix this fault then you'd be better off just chucking it away and buying a replacement as it will be cheaper.
Mar 15, 2010 | Sharp AQUOS Blu-ray Disc Player
Headrest built-in DVd with disc stuck...help
Look for a small hole under or on the side door assembly, if found use a paper clip or other thin metal straight object and insert into hole this will release the disc clamper and open the door.
Nov 25, 2009 | Televison & Video
Dvd player won't read disc
I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Aug 18, 2009 | TMI Products Vizualogic Headrest Pair...
4 DVD players unable to read the disk.
The disc cleaners that can be purchased are little more than brushes that can clean dust only. If you can gain access to the lens of each unit, try cleaning the lens carefully using a cotton swab and alcohol. That should resolve some of the problems. If not, then for some reason you have multiple failed optics assemblies.
Dan
Feb 16, 2009 | Philips Audio Players & Recorders
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
DVD playback
Samsung dvd players are known for bad spin motors. You may try to clean the laser and see if that changes the disposition of the problem. If there is no change and with the top of the unit off,if you see the pin point of laser on top of the disc, and the disc moves or shivers, the chances are it is a bad spin motor. In most cases, it is not cost effective to replace the motor. If an auxillary line in jackis available , buy a $30 dvd to replace it rather than taking it to a service facility that will charge you the same amount to evaluate it. Scrivitron
Jun 15, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Apr 27, 2007 | LG DK 9411P DVD Player
Open Questions:
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
