Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Toshiba television
maggie2008 on Mar 11, 2008
I f you drop a television can it be repaired if the outside didn"t break just cracked the upper right corner???
Comments:
Mar 11, 2008
- The screen isn't cracked it is the black plastic around the television how do you know if the tube is broke would it have a white line when you turn it on?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 11, 2008
Very Helpful)
BFixed
Rank: Guru
Rating: 86%, 86 votes
If the glass picture tube is cracked it is not repairable. In some cases it would be possible that the tv would still work if it has a cracked glass but it would not be advisable to use it as it could allow x-ray radiation to escape. The tube is a vacuum and a cracked tube would lose it's vacuum (**** air inside) and cause it to instantly burn out when turned on. Sorry :(
Was this helpful?
Yes
No
Related Problems
toshiba 32w8db works for about half an hour then has a...
the tv will has suddenly shut off by itself and the red...
TV works great, only one problem that we can identify - it...
I was trying to program my DVR remote to work with my...
When we turn on the TV set, toshiba CF36G50, it is really...
Can you Help with these Standard Television problems?
Cable Connector
Solve
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable... (More)
Toshiba model tny3v71 isn't getting...
Solve
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden... (More)
I need an audio output ic unit...
Solve
I have a Toshiba TV (model# 23319197). The audio output ic part is out and Toshiba has discontinued... (More)
child lock
Solve
is there a way to mayually remove a child lock on a toshiba back projection screen television?
Black lines along bottom,...
Solve
I have had my Toshiba CF36G40 TV for about 10 years or so. Only recently, about 3 months, I have... (More)
Sponsored Links
Describe your TV problem:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
