Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Color is too dark
I do not have a manual on this tv. Color has been progressively darker and I do not know how to get to the menu to lighten picture. I am wondering if this is because one of the lights is going out?
  • sujo0507 Oct 13, 2008
    tv just got really dark & very very hard to see pic.could it be the bulb?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Unplug the TV,remove the front panel to gain access to the CRT sockets - loosen the screws that hold the sockets to the necks of the CRT's - now unplug and replug each socket from each CRT - this will remove any dust resistance on the pins of the CRT's - after doing this, the brightness level should go up.
Posted on Mar 11, 2008
SOURCE:
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
I have a phillip magnavox big screen tv it works fine but the color is too dark i think i need a picture tube
If its the one indicated here or one like it :
The picture tube type (CRT) rear projection tubes require annual cleaning.
With set off and back removed locate the three large black lens atop the chassis--hard to miss them.
The are the red, green, and blue tubes and are your light source for the picture---------if dark and they are dirty or dusty the picture will be darker and not as sharp or clear as it once was..
spray some glass cleaner on a paper towel and wipe them clean.
Do not touch anything else in set and do it with set unplugged.
put back cover on and see if picture is noticeably improved; if so do it once a year or more if in a dusty place.
Let me know if you have questions.
Mar 16, 2012 | Philips Magnavox 51MP392H Rear Projection...
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
JVC TV THE PICTURE IS DARK EVERYTHING ELSE WORKS GREAT
there so many things which can cause that to happen an these are thwe following,
i a tube has to be tested
ii a line transformer
iii vedio amplifier
this tests can be done in w/shop where other tvs are of the same.
Mar 27, 2009 | Televison & Video
Tv is dark
looking on the back of ur tv near the cable input jack there might be an area where u can adjust the brightness on the flyback transformer. if there isn't you will have to remove the back of the tv and adjust it this way. PLEASE DO NOT TOUCH ANYTHING OTHER THAN THE BRIGHTNESS KNOB ON THE FLYBACK, CAUSE YOU MAY BE SHOCKED. so please be careful.
Mar 11, 2009 | Zenith SY2765S TV
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
