Question about GE GSH25JFR Side by Side Refrigerator
TFX25JRYFAA SIDE BY SIDE GE REFRIGERATOR
My ice maker driver motor will not turn when button in front is pushed (Both whole,and crushed ice). When the control is switched to the water position, we have no issue. I tested the motor outside of the refrigerators, and it seems to work fine.
Don
Is not cooling enough in bottom
Posted on Mar 21, 2008
    President:
  • GE Master
  • 2,651 Answers
Try taking off the dispenser front and check the "switch " controlling water /ice. its a micro switch your connecting with as you change from one to the other{ice to water) im assuming that the switch is not being activated. plungers get stuck switch gets old
Posted on Mar 11, 2008
SOURCE:
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER
to solve the frozen food problem, turn the temp back to 4. this should be the factory recomended setting. the only dispensing crush ice is probably a bad solinoid. you will find this behind the back wall. it engages to lift the thin metal rod on the bottom of the ice bucket to dispense cubed ice. and the ice being frozen in the bucket is probably a bad ice flapper in the door. it's letting warm moist air into the ice bucket that is freezing
Apr 23, 2010 | GE GSH25JFR Side by Side Refrigerator
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
there is a door in the bin that switches the cubes empty the bucket and make sure its not jammed also take the bucket out push cubes hold down the door switch not the one that turns the light off unless you unit only has one and push the switch with the door open in the back a leaver in a hole should jump up it not switch it to crushed and try it again if it still don't then the solenoid is bad or frozen
Feb 18, 2008 | GE PSS26SHRSS Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
153 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
