Question about Canon PIXMA MX310 All-In-One Printer
Scanning I connected the cable from the printer to the computer, but when i pressed scan nothing happened. Do i need to open something on my desktop first? what am i doing wring? thanks.
  • Anonymous Mar 20, 2008
    got a imac, it will print but nothing happens when i push the scan button
  • 31 Answers
Are you sure that you install its driver and software? you must first need to install its driver and software properly
Posted on Mar 11, 2008
    Sergeant:
  • 317 Answers
Be sure your printer is online
SOURCE:
My printer works, but when i scan it says connecting to pc and then nothing happens
Hi Margi!
It probably means that the scanner isn't configured well in the computer. What you should do, while to printer is turned on and connected to the computer is to go to the device manger (right click on "my computer" or "computer", and then go to the tab named "device manager"). go to "universal series bus controllers" and press on the plus sign. you should then have a list, search for "USB composite device" in that list. when you find it, right click on it and then left click on "uninstall" or "remove", approve it (press yes or OK) and after it done, disconnect the usb cable that connects the computer to the printer and restart the computer. only after the computer is booted up completely, you should reconnect the cable. after you do that you should get a pop up that says that new hardware is being installed (or something like that). wait for it to finish and after it says "you new hardware is installed and ready" (should appear near you computer clock), try to scan, it should work fine now. Good luck!
Dec 11, 2010 | Computers & Internet
Nothing happens when i press scan button
Nothing will happen unless it's connected to a computer with scanning software running. If you want a copy you press copy and it will scan and make a copy, but if you want to scan you need the software to tell it how to scan, what you're scanning, and how to save the scanned image.
Feb 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Scanning start problem
You need to have the scanning software running first, I use Picaso that comes with some windows.. You open the scan software and tell it what you are scanning and if it sees the scanner you can scan from the computer. If the software doesn't open when you press the scan button you may not have compatible software on your computer.
Dec 08, 2009 | Dell 946 All-In-One InkJet Printer
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
Oct 29, 2009 | Brother MFC-5840CN All-In-One InkJet...
I need to know how to scan
make sure the software cd that came with the machine is installed, then turn on the machine and make sure its connected to your computer and your computer is turned on and you are on the desktop, press on the scan button on the machine, scanning should come up on your computer if it doesn't come up then press start, then run, type: mspaint and click OK
in paint, press File and then select from scanner or camera, scan and save your scan to your computer.
Oct 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Nothing happens when I press the scan button
When you press scan, the unit must be connected to your computer and the computer needs scanning software running, if you want to make a copy you press copy and it will scan and print, in order to scan it needs to know where and how to scan and where to store the image.
Sep 14, 2009 | Canon Pixma MP500 All-In-One InkJet...
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
Scan setting
jai un probleme sur mon canon MP450 code errore 5800
Apr 15, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
48 people viewed this question
Clive
Clive
old marine
old marine
Ekse
