Back to:
Tags:
Xerox DocuPrint N2125 Laser Printer
Laptop on a secured Wireless Network is unable to...
posted by Nacar on Mar 11, 2008
Laptop on a secured Wireless Network is unable to ping N2125 Printer on a Wired Network but is able to ping other printer models that are on the Wired Network.
Once we switch the Laptop from Wireless to Wired, it will be able to ping the N2125 Printer. Could it be a setting on the N2125 since the Laptop is able to ping other printer models that are on the wired network?
Please let me know what details you need to troubleshoot this problem. Thank you.
Comment by Nacar, posted on Mar 11, 2008
Which network setup? On the N2125 printer or the Laptop? I'm guessing it would be the N2125 printer network setup because the Laptop can see a different model printer on both wired and wireless. What should I look for on the network setup of the N2125 printer?
But may I re-iterate that the laptop can access a different model printer on both the wired and wireless approach which makes it confusing.
Sorry, but I'm a beginner. We did enter the IP address manually on the printer.
I meant beginner on this forum stuff. I know my way around the operating system and network settings. What network setting information would I need to verify?
The laptop is on the domain, not a workgroup.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
IB4G2008
Rank:Wiz Wiz
Rating: 82%, 1915 votes
well..it's all about the network set up, and whether that N2125 is visible on the right network..check the settings and then you'll find more value
Comment by IB4G2008, posted on Mar 11, 2008
on the laptop..I'm assuming since the N2125 is accessible on the wired approach, that the issue is in the wireless configuration. I'm assuming you've done the IP watusi, right, where you enter the IP address manually, from the printer, yes?
just went through something like this a few weeks back, with a dell printer..it's a little quirky.
ok..beginner..send me a note through my contact info on my profile, and we'll arrange an E Housecall where I can see your computer from here in Hawaii..
in your workgroup settings..
Rating Locked! (?) Nacar has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Laptop on a secured Wireless Network is unable to ping N2125 Printer:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
I dont' understand the symbols on the X 4560 printer
Printers
HP Photosmart C5200 All-in-One. After removing spent...
Printers
printer flashes "refer to printer...
I keep getting this error message, yet there is nothing in...
at work i hooked up the xerox docuprint to my hp laptop my...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
