Gestetner 2302z photocopier toner light stays on but has toner in it
I get error code 63 and then c- how do I it rest it and where can I get list of error codes and manual. This copier is the same as copystar 1435 and 1455.
  • 51 Answers
The error code has got something to do with your fuser. Either the lamp is blown, the thermistor could just be dirty or the fuse has blown. These manuals are very old, do not know if it will be easy to get the manual.
Posted on Mar 17, 2008
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
Gestetner dsm730 error code sc590
SC 590 - Toner collection motor error.Possible causes:
- toner collection motor defective
- too much load on the drive mechanism
- poor toner collection motor connector connection
- toner collection motor sensor defective.
Reset procedure:
1. Turn OFF/ON the power switch.
If the trouble don t reseting press the Clear (yellow) key press 107 press and hold last more 4 seconds the Stop/clear(red) key,enter inSP mode,then turn the main power switch OFF/ON.
Feb 04, 2013 | Gestetner DSm730 Black and White Copier
Error code sc322 gestetner
It's an error code for a laser synchronization error. Possible causes according to the service manual:
•Laser synchronization board connectors loose, disconnected, or
damaged
•Laser synchronization board defective
•LD drive board defective
I've also seen where toner leaks and covers the laser sync board and causes this error. Try cleaning any toner off the Sync board and see if that fixes it.
Oct 11, 2012 | Gestetner DSm745 Black and White Copier
How can I solve error code E-1 on my gestetner 2722ztd photocopier? the error occurs when I turned on the power
u need to get a full error code press star or hash key to get the rest
my gues its 101 which is exposure lamp brocken or something to do with optics
Nov 02, 2010 | Gestetner Office Equipment & Supplies
Gestetner 428 colour photocopier: background effect all over
It's possible it could be the transfer cleaning unit, but it's more likely to be the fuser or the transfer belt itself. If the hot roller is old or dirty or the press roller isn't providing enough tension, all of the toner might not be getting fused to the paper.
If only one color were showing mottling, it would probably be the developer, but it's unlikely that all four developers went bad at the same time.
Jul 03, 2010 | Gestetner Copier
Photocopier comin up with error sc550 on gestetner 1302
The problem in the fusing unit.Clean and verify the heater lamp,thermistor and thernofuse continuity.
Sep 26, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3235 Mono Photocopier
I believe that model is fairly old.... Dosen't the control pannel have a red light showing what door or cover is opened??? Try all the doors and covers and look in the last spot you pulled a paper jam from...
May 19, 2008 | Office Equipment & Supplies
Gestetner 2302z
After replacing the toner cartridge you did remove the plastic strip that holds the toner in place?? If you did, on the control panel is a little sunken black button. Just take a pen or then object and hold the button down until the light goes off. This can take up to ten minutes to go off.
Try www.copiertoner.net for spares.
Mar 18, 2008 | Office Equipment & Supplies
Gestetner 2302Z copier
c-32 is a scan reverse problem. there is no c-36 code. If you mean c-63 it is a fuser thermistor problem. Lawrence. I have a service manual for the Mita 1435 which is the same machine. The scan reverse code could be dirty rails where the optical assembly. ( the light that goes back and fourth) Clean and lube the rails.
Mar 12, 2008 | Office Equipment & Supplies
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
168 people viewed this question
jasbo
jasbo
