Question about InFocus Lamp Projector Lamp for LP240 [ SP-LAMP-005
InFocus LP280 problem
I've been using our InFocus LP280 projector about 10-15 times per year for the past 3 years (about an hour each time).  Today, out of the blue, the colors started going wonky - in and out-- the photo would turn to blues and greens and then back to normal, and all of a sudden a bright yellow spot appeared in the middle of the projection.  Within a minute, the spot turned to bright red.  I turned the projector off.
I have tried to find support on InFocus' website, but to no avail.  Did my lamp burn out, or is this simething more serious?
  • Anonymous Jul 01, 2008
    dunt work
  • 563 Answers
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Posted on Apr 02, 2008
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
www.projectorreviews.com/articles-guides/lamp-life-and-brightness-2/
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
https://community.spiceworks.com/.../2235-resetting-lamp-hours-on-a-sh...
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
https://www.youtube.com/watch?v=sPGZSJXpxqI
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
InFocus LP280 turns on then shortly turns itself off. Will not stay on.
There are 3 things that you should check.
1. The lamp
2. The firmware version. (the last is the "1.26E")
3. The power supply (may exibit oxidation in the ECA main board conector). And you need a technician to clean it.
Apr 08, 2010 | InFocus LP280 LCD Projector
My projector makes a high pitched noise upon power-up then noise subsides after warm up and returns occasionally. what can that be? My projector is only 3 years old. and my only other problem has been...
sounds like the colorwheel. the bearings are starting to go on it due to excessive dust and heat. since it's a motor, it's bound to wear out eventually. it will need to be replaced. you could buy the part and do it yourself or send it in for repair. either way, try av solutions in ny. they're really good and they're an infocus service center. www.avsolutionsny.com.
the lamps should be good for 2000 hours. if you use it that much per year, three lamps is normal. but it's best to keep the projector clean and free of dust to extend the life of the lamps. dust keeps in the heat that the projector is trying to expell. heat will kill the lamp and possibly overheat other circuits and components. use canned air to blow it out.
Dec 03, 2009 | InFocus ScreenPlay 5700 Multimedia...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
How to Clean the lense on a Infocus LP280
outside- lint-free microfiber cloth and canned air. inside (projector)- canned air.
Nov 09, 2009 | InFocus LP280 Projector, Factory...
Infocus LP280 projector will shutdown itself
The Lamp cooling fan is not working or the fan speed control chip/circuit has failed. Do not run the projector until it is repaired as this condition rapidly destroys the lamp!! If the cause of the problem is simply the fan itself. It can quite easily be acquired and replaced by someone who is electro-mechanically savvy.
If the problem is on the main board (also very possible) it is substantially more difficult to repair and should only be done by someone who is an order of magnitude above just electro-mechanically savvy.
Also if the problem is in fact the main board an authorized service center would just replace it!
(hang on to your wallet)
Cheers
Feb 26, 2009 | InFocus LP280 Projector, Factory...
No Image
You may be hearing the color wheel turning. Make sure the lamp is installed correctly and lamp access door/plate is properly closed.
Jun 24, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
539 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
