Question about Sony PlayStation 2 (PS2) Console
Disc Read Error
PS2 game that has only a few very minor cosmetic-looking scratches, that's unwilling to get past the loading screen. PS2 console is new, so the problem isn't there. Not ready to commit to boiling and/or using toothpaste, and there's no resurfacing services where I live. Ideas, -sane ideas-, for home remedy?
  • theresat May 18, 2008
    my playstation2(slim version) will only play bootleg movies and wont play guitar hero 3 and i got it cleaned and the lens is not scratched, it wont even play the dvd menu the screen just goes black
Switch dianosis from on to off
Posted on May 16, 2008
Trade the game in and buy a new copy
Posted on Mar 11, 2008
Ps2 disc read error
often as not, it's the disks, not the console. check the disk condition for fingerprints and deep scratches
Dec 03, 2014 | Sony PlayStation 2 (PS2) Console
Playstation 2 shows disc read error
it shows a disc read error on games that aren't even scratched and i had a game that was scratched and in skiped alot in game play but when i got the same game brand new it had the same problem
Dec 30, 2009 | Sony PlayStation 2 (PS2) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Slimline PS2 has started to only read some games, not others
Hello. Base on you're problem description, and from my own experience, I believe the problem is with your lens. I recommend that you take a closer look in to it. Take it to your local game store and have it cleaned.
Jun 16, 2009 | Sony PlayStation 2 Slimline Console
Had ps1 game resurfaced, no longer works on ps2
Sounds like you need to get your money back ..the resurfaceing can also do more bad than good
But a little trick lightly rub a crayon over the disk ,,old pantyhose works great rub it off from center out then try your disk ,,have saved many good games that way
Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Disc Read Error
there can be many reasons.
1 u hav not inserted the disc properly
2 the discs hav scratches
3 your laser has been damaged and needs to be replaced
tell me if there's more
did u take it anywhere?
Jul 04, 2008 | Sony PlayStation 2 (PS2) Console
I need help
For "grit2t", check your disc and see if it scratched or cracked, etc. If it is, then the screen would say "Disc read error". Maybe your PS2 might be old or dusty. You should clean it, pretty much. You should go to http://www.youtube.com/watch?v=o4aDoNScvNA, for help on cleaning your PS2. This should help you...
Mar 29, 2008 | Sony PlayStation 2 Slimline Console
Playstation won't read game disks
What you probably have is a disc read error, if you don't want to get a new system first you can always open it and repair yourself but that voids the warranty but is voided after the 30th day, I have tried it a few times in the past and it works but is time consuming and if your not careful you can break it beyond use. But if you're brave read this article.
http://arstechnica.com/articles/paedia/hardware/ps2.ars
Dec 11, 2007 | Sony PlayStation 2 (PS2) Console
Slim ps2
disc not scratched? laser maybe dying! how did you clean the laser?
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
