Question about Dryers
Side by side refrig,not working - Dryers
    Problem Solver:
  • 12 Answers
What is not working is the freezer freezing or the fridge section not cooling i need more info
Posted on Mar 11, 2008
  • Shirley Freeman
    Shirley Freeman Feb 06, 2014
    the fridge section, then the veggies in the 2 drawers become all frozen and i have it set on 2
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE profile side x side refrig. The
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
Oct 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
MY SIDE BY SIDE REFRIG IS NOT COOLING ,THE FREEZER WORKS GREAT BUT THE REFRIG ISNOT COLD WHATS THE PROBLEM. THANKS JOSIE
check to see if fan in freezer is blowing... if not then that's most likely your problem... air passage to refrig side may be blocked if it is blowing
Sep 24, 2009 | Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our ge refrig runs constantly,freezer is freezing but the refrig is not cooling. I cleaned the dust and dirt out of the bottom and back of refrig.
See if the fan in side the frig is working It mite be on the freezer side If the fan is not working it will not blow the cold air in to the frig side
Jul 12, 2009 | Refrigerators
GE Side by Side refrig. - Freezer not working but refrig. is
could be many thing , low on freeon also defrost problum , open panel of your freezer side and check coil behind it
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Dryers Logo
Top Dryers Experts
Marvin
Marvin
