Fried Motherboard I broght the whole tower to her friends (Embry Riddle Aeronautical University) at first they thought it was the power supply, after purchasing a new one I brought it back to them at which time they said it was the motherboard, I am, of course, assuming they checked the hard drive. If it is the hard drive and not the motherboard is there any way to retrieve the information off of it? FYI... I have 3 other working towers but none of them have the same connections for the hard drive as this one. Maybe I should go out and purchase a hard drive and see if that does it?
  • 504 Answers
If the hard drive has completely crashed, it will not be possible to retreive the data from it. If it is a situation in which the boot sector has become damaged, it may be repairable. Yes, I would try a new hard drive before you go with the motherboard diagnosis. They may be completely correct, however, I did have a faulty hard drive that displayed the exact same symptoms you described. If the new drive works, you just need to see if someone can salvage the data off the old one. If it IS the motherboard, your data should still be safe. If it is NOT the hard drive, be aware - you will have spent money you will not be able to get back.
Posted on Mar 11, 2008
Question regarding aviation.?
Embry Riddle is one of the most expensive colleges you can attend for flight. There are many others such as University of Cincinnati and University of North Dakota that offer college programs in flight and aviation. Airlines do want college degrees so it's really a pretty good idea. I'd check out tuitions at other colleges that offer aviation.
Jan 04, 2017 | Aircrafts
My hp mini tower will not restart
Your power supply is probably bad. Try plugging in directly to the wall and try it. If you have a meter, you can open it up and turn it on. Check the voltage on one of the unused plugs coming out of the power supply, the box in the back with the a/c receptacle on it. Find a plug with a yellow, 2 black and a red wire. Yellow/Black should be 12v, Red/Black should be 5v. Normally people lose the 12v (get only 8v) so the motherboard comes on but not the HDD.
If your prw supply tests OK remove any cards you have and try turing it on with no cards. If it powers on, add the cards back one at a time until it won't power on and that card is bad. Normally this would be a modem card that connects to a phone line.
If the pwr supply test bad, take some pictures of the inside with your phone and remove the power supply (4 screws on the back) and disconnect all the cables that go to it. Check the label for watt ratings and a part number or take the whole P/S to a computer store where they will be $45. Make sure the one you buy has the same type connectors, same or more watts and screw holes in the same place (ask for help). Or you maybe able to order online using the HP part number ($80) or from eBay. Replace the power supply, plug everything back in and turn on. Really pretty easy.
Apr 16, 2014 | HEWLETT-PACKARD Hp Fm049ut Workstation - 1...
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
AFTER A STORM HIT, THE DESKTOP SLIMLINE TOWER WOULD NOT POWER ON..
You can try replacing the power supply, but if it wasn't plugged into a UPS it is likely that the motherboard is fried.
Jul 10, 2011 | Computers & Internet
I have an Asus M4A89TD Pro/USB3 Motherboard that I'm using to build a new PC. After I finished assembling the tower I turned it on and began setting my BIOS. I only set the date and time when my whole...
I would re-seat the power connector from the power supply to the motherboard. If you are able to test the power supply output, that would be helpful as well. The problem as you describe it points towards the power supply failing.
Apr 01, 2017 | ASUS Computers & Internet
My friend has just moved and his comp was working before. But now when plugged into power the tower has no power. Any suggestions to what might be going wrong?
firdt check another outlet ,that outlet maybe dead. then check if the power cord is properly seated in the plug at back of tower, then check if it has a reset button power supply, then open the case and check if duing moving the inside power connection came loose. check all the connections, then If it still wont work, either the power supply went dead or somehow the system motherborad fried
Jul 12, 2009 | HP Desktop Computers - Hewlett-Packard...
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Computer will not boot
Bios is erased, clear cmos thru motherboard; pins
Apr 05, 2008 | EliteGroup P4VXASD2 Motherboard
Fried Motherboard
if you are sure the entire thing is fried, and you have to be sure, i would reccommend a Gigabyte GA-EP35-DS3R motherboard, if your processor is an intel, it does down to pentium d, and ddr2 ram. i bought one of these and i can still upgrade to core 2 quad if i wanted. (does not support AMD processors,or ddr1 ram). will work for a long time, 5 year warranty at some places
Mar 09, 2008 | Intel Motherboard
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
