Question about Sony CDX-M630 CD Player
Sony CDX-M630 will work only with remote.
The radio works well with remote.  The face controls quit working one side at a time.  Now no controls work, unless the remote is used.  It opens and closes as usual when key is turned on and off.  Help??
  • 2 more comments
  • Anonymous Mar 12, 2008
    Yea I the same problem and to make matters worst my remote does not work all the time. The only button that will work on the deck itself is the off buttom.
    Sorry I was the guest before (tried signing up but wont work for some reason) I was tuning my unit when the problem began. The unit was playing and then suddenly turned down and off by itself. Had to reset before it would repower. Never had an issue before and all buttons stopped working at once.
  • Anonymous Jun 30, 2008
    Is there any way I could have pushed the wromg buttons to make the remote work but not the face?
  • qtbass Aug 28, 2008
    I have the same cd player and just recently began experiencing the same problems. I am an engineer so I took the unit out and took it apart to evaluate the problem. What I found was that the ribbon which powers the face plate eventually cracked and broke in two where it enters the faceplate and makes a sharp angled bend. I would imagine this would be a very common problem with any radio/cd player with this fold out type faceplate. Until they design a better power supply for the face this will continue to be an issue. I could order the parts and fix it myself but I don't feel that the unit is worth the trouble as it will fail again soon.
Possibaly the issue is the ribbon cable that connects the faceplate to the head deck i had the same issue
Posted on Jul 10, 2008
Where i can find the remote
For Sony CD-M630 cd player, you need following remote control..
147711014... RM-X117 remote Control
Available in Sony Accessories Store for $34
Hope this info will help you.
Thanks.
Feb 11, 2010 | Sony CDX-M630 CD Player
I need a wiring diagram for sony cdx-m630
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 27, 2009 | Car Audio & Video
It doesnt work after battery when dead in car.. i have no remote....i got it with the car and it worked great, now it just open up and nothing....
What has most likely happened is the when the car died it was probably jumped off. Anytime a vehicle is jumped off, especially off a much larger vehicle, a "jump" of voltage is sent throughout the vehicle also known as a surge. The surge travels through the vehicle's electrical system and sometimes blows bulbs, fuses and relays. The back of your radio should have a fuse check it because It's probably blown. If the fuse is good refer to your vehicle manual to locate the fuse panel and find the radio fuse it might be blown. Hope this helps
Aug 03, 2009 | Sony CDX-M630 CD Player
Hi i need a remote for cdx-m630,where can i get one from?thanks i am from Toronto
You need remote under following part number for CDX-M630
47711014 RM-X117 REMOTE CONTROL for $33.95
It is available in Sony Accessories Store (copy link in browser search bar)
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=CDXM630
Thanks.
Jul 16, 2009 | Sony CDX-M630 CD Player
Operation buttons and sub display are failing
go to ebay and type in the model number of the unit and it will bring up some part that can fix the problem. i had the same problem and i just ordered the part. its actually a ribbon connector. im sure you just open up the radio and take the old one out and connect the new one up. this seems to be a common problem with this unit. the ribbon just starts to tear, and as it tears, you will start to lose functions on the stereo. i happen to like this stereo, so i decided to repair it. good luck with yours.
david
May 31, 2009 | Sony CDX-M630 CD Player
Cd face will not function
sounds like the flexi cable is faulty, try www.carradiospares.co.uk
Mark
Nov 19, 2008 | Sony CDX-M630 CD Player
Sony cdx-m630
I have a few suggestions that may help. Have you checked the fuses?There is on on the stereo and one in the car's fuse box. Are all of theconnections from the wiring harness secure? Make sure these are tightand show no signs of damage, especially the ground connection. Also, ifthe face is detachable, check the connectors (on the face and thestereo) for damage or dirt or anything that would prevent a goodconnection. Pushing the reset button should not have prevented you fromoperation of the unit, so it has to be either an external fault (likewhat I described above) or an internal problem. How old is the CDplayer? If it is still under warranty, I would call Sony or go to theirwebsite and speak to one of their techs. You can go to the site byclicking on the blue link: Sony Support Hope this helps... Please take time to rate how helpful this was. Thanks and good luck!
Sep 10, 2008 | Sony CDX-M630 CD Player
My Sony CDX-M630
First, make sure that the face is the correct one for the unit. I have had a couple of friends buy from salvage yards and the owners of the yards will take the faces off and put them all in a box - but forget which one goes with which. If this is the correct face for the unit, and all of the connections are good, the face should be displaying "CODE IN". This is where you would enter the unlock code - with the REMOTE. If you don't have the remote, then I'm not sure if you can unlock the unit. I've been to a few sites researching this question and have yet to find a way to enter the code without the remote. If you didn't spend very much on the unit, then it's not a big loss, but I would look into buying one new. It's almost impossible to get the default codes from the manufacturer for a used unit without the proper identification - i.e. receipt, product registration code, etc. Hope this answered your question. Please take time to rate how helpful this solutions was. Thanks and good luck.
Aug 27, 2008 | Sony CDX-M630 CD Player
Sony CDX-M630 CD Player Problem
Mine did the same...it will stop working all together soon...repace the ribbon you should be fine
Apr 22, 2008 | Sony CDX-M630 CD Player
Sony CDX-M630
not open the face? or not get on the stereo? if not open the face maybe is too fit on the space for the stereo, check down if have space, if dont get on, check if are well conected
Nov 02, 2007 | Sony CDX-M630 CD Player
Sony CDX-M630 CD Player Logo
449 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
