Question about Maytag 30 in. CSG7000 Gas Cooktop
Ignition stays constantly on, How to fix it or shut it off
My cooktop is ~9 years old. Today the 4 electric ignition went off for no apparent reasons. It has been on for 4 hours with the annoying clicking sound. I cannot find a electric swith for the cooktop itself. And I cannot turn the main switch off because I need to keep my refrig on.
Any suggestions?
THanks,
    President:
  • Maytag Master
  • 2,651 Answers
Its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Posted on Mar 11, 2008
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Jun 21, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Not working although power supply is on
Very likely your power supply is faulty. With 220 volts both legs must have power for the burners, but the fan will run on only one leg. Hope this helps!
Jan 01, 2009 | Jenn-Air JED8430 Electric Cooktop
Igniter issue for monogram gas cooktop
Be sure all caps are on correctly, then make sure the igniter is clean. Try using a tooth brush with soft scrub around the igniter, rinse, dry and try it
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | GE Monogram ZEU36 Electric Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Maytag 30 in. CSG7000 Gas Cooktop Logo
354 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
