Question about Epson Stylus Photo 780 InkJet Printer
Stuck carriage carriage does not return all the way to the home position, and makes a loud squealing sound as it stops
  • Anonymous Mar 18, 2014
    I just replaced the black drum and then getting this squealing sound
  • 807 Answers
Open the front and look at the horizontal bar that the head slides left and right on. It's the shiney one below the belt.
Clean it and lightly oil it with something like sewing machine oil, or a really soft grease all the way along. Also look at the rail at the top of where the head slides and do the same there.
Posted on Mar 11, 2008
WHAT IS THE LIKELY CAUSED OF A LOUD SQUEALING NOISE COMING FROM THE ALTERNATOR SERPENTINE DRIVE BELT SYSTEM ? IS IT THE ALTERNATOR OR SERPENTINE BELT?
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
I have a loud squealing noise upon starting the car. the squealing normally lasts about 30-45 seconds. sometimes the noise will appear aftrer pulling off from a stopped position, as well. all belts
Try to tighten the belts a little firm.Sounds like when engine idling no squelling only when about to take off .Some times belts may seem ok on the outside but if you look on inner side you tend to see cracks in the belts .
Jan 06, 2014 | 2000 Mazda 626
1998 Ford F150 5.4 liter V8 squealing problem. Ok, I have this loud squeal that sounds like a pulley or belt. It is getting worse by the week. At first, I would spray some WD40 on the pulleys and it would...
I don't think its the CPS, but I do know that WD40 will make a squealing belt even worse. If you havnt replaced the belt yet, I would do that.
Let us know if that helps.
Jan 22, 2013 | 1998 Ford F150 Regular Cab
When I try to print I get a LOUD tapping noise. Also ink cartridges do not return to middle position when I open the machine, though I can manually move the cartridge case (which may or may not have been...
Try unpluging the printer from the wall power then move the carriage all the way to the left side. While you are moving this make sure there is nothing blocking or catching the carriage. It should move over easily with using a lot of force. After it is all the way to the left plug it back into the wall with all the covers closed. It should reset itself to the default position. After it stops open the lid to see if the carriage comes to the cartridge replacement position.
Apr 13, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
IBM Selectric Typing carriage doesn't stop moving. Stuck key?
It sounds like a possible tab knockoff problem. This could be a small spring loose or broken in the escapement portion of the machine or the final knockoff in the tab unit out of alignment. You can try setting a tab before the end of the carriage by holding the carrier in place and using your other hand to press Tab Set, but the alignment may be just far enough off to keep you from actually setting the tab. One other thing that sometimes will cause the problem is the pitch setting lever is between the two pitches. Make sure your pitch setting lever is seated in its home position.
Mar 27, 2009 | IBM Office Equipment & Supplies
HP 2210 Printer - Scanner sounds like it is stuck
It's possible that the mylar strip has become contaminated with ink and/or dust or is loose.
The mylar strip runs horizontally along the length of the printer. It threads through a slot in the carriage and is connected by hooks on both sides. Make sure that it is still connected on both sides.
If it is connected properly on both sides, try cleaning it. Gently rub a moistened lint-free cloth back and forth across the strip. The easist method is to squeeze the strip between your thumb and forefinger along with the damp cloth.
If the strip is not loose and cleaning it does not cure the problem, you'll probably need help from a certified HP technician.
Mar 25, 2009 | HP PSC 2110 All-In-One InkJet Printer
Squealing NOISE possibly from fan belt
Belts stretch from new. Try to tighten them again. Hopefully the are not glazed or this may stay with you.
Dec 14, 2008 | 1988 Dodge Grand Caravan
Epson Stylus Photo 780 InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
