Question about HTC Touch P3450 Smartphone
Call display problems
My call display often does not work properly... either not showing a name and number until the call is answered or only showing the number and the name is cut off. This applies to numbers that are stored as my contacts as well. Very frustrating!! Any help would be much appreciated
Same problem here. I have found that to avoid such problems you need to restart the phone once every 3 or 4 days. You This solves the problem.
Posted on Mar 27, 2008
Answer only carries out to 4 decimal places
Press the MODE button until the screen shows: [Fix Sci Norm] for the display mode, then press the number corresponding to Norm (ie 3 for Normal) then either 1 or 2. Display mode Norm1 shows numbers that are less than 1 in scientific mode, whereas mode Norm2 retains decimal format where is fits on the display.
Nov 22, 2011 | Casio fx-300ES Calculator
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
Programm the machine to show my comp name and
Press the dataregistration button,when dataregistration is displayed press ok or start.When user settings is displayed press ok/start.Scroll with tha arrows untill unit name is displayed press ok and insert comp name ,press ok.To insert fax number scroll to unit tel and press ok and insert fax number.
Aug 17, 2009 | Canon FAX-L350 Plain Paper Laser
How do I change the persons name that is programmed on the phone already?
go to administrator phone
usually are receptionis phone
press MODE button
press ADMIN
key in pasword "0000"
display show phone name
press HOLD to skip
display show DN ID
DN stand for extn number
key in extn number
the exiting name will shown...use scrool n page for backward n forward the cursor
key in the person name
press hold to confirm
to exit press MODE button untill time n date r displayed
Apr 07, 2009 | Toshiba DKT3010SD Corded Phone
NORSTAR m7310
To Log Into System Programming:
Using the navigation keys, as displayed below, follow the next simple steps:
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
Changing employee name on extension
http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 30, 2008 | NorStar M7310 Corded Phone
Contact name doesnot appear properly when a call comes on the phone
For the names to be displayed, you have to save them against the numbers that are displayed.
Sahaja Yoga is the Only Way to Save the World and is the Mahaa Yoga.
Sahaja Yoga is FREE OF CHARGE.
Apr 02, 2008 | RIM BlackBerry Pearl 8100
Caller ID Display
There is no setting in the phone that will show you the Caller ID number without the name. It sounds like your telephone company is not sending the name.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Mar 31, 2008 | Panasonic KX-T7633 Corded Phone
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
HTC Touch P3450 Smartphone Logo
Top HTC Computers & Internet Experts
Justin
Justin
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
